changing brake system
katz79
45
2
1,508
this is what i've done on my car:
a) twin pot evo 3 rm700
b) lower arm rm300
c) steel braided hose rm150(4 nos)
d) double layer servo evo 3(persona can opt for honda servo) rm 150.
e) rapidstop 800 degree rm480. want cheaper search for pajero v6 pad.
u may find cheaper than this price if u know how. labour charge maybe up to rm250 depend on the formen. if u want basic just opt for twin pot and lower arm only but persona stock servo are crap. u might as well thinking changing that.
braking performance will be increase tremendously if u take above step, i can assure you that. but don't always do hard braking coz it will increase ur fc. happy modding:smokin:
hardcorecar
77
Sabah
b) lower arm rm300
thanks man..this really helping a lot...
katz79
45
2
1,508
no problem bro. i only now a little bit of knowledge for campro mod. not many campro owner opt for this upgrade coz it quite costly unless u are prepared for this budget. at least to solve persona common brake issue is to change their stock servo to honda/nissan double layer servo. this will counter the spongy effect from the stock brake system.
ken yeang
6,617
1,327
b) lower arm rm300
hahaha, not just increase FC, but also make the tyre botak very fast.....
Of course, there is always the price, if wanna drive excitingly.
My auntie drive like snail speed, her Unser tayar lasted 5 years. My fren drives his civic like mad, within half year tayar botak liow...
b) lower arm rm300
c) steel braided hose rm150(4 nos) - where you got them? chop shop also?
e) rapidstop 800 degree rm480. want cheaper search for pajero v6 pad - means evo3 twin pot same as my VR4 twin pot brakes....Trestor Blue advantage pads at RM105....:driver:
katz79
45
2
1,508
yes i got the hose that came together with the caliper. don't know cheap or not. if lucky can get project u disk together with caliper. mine got slotted disk.
evo 1,2,3 and pajero v6 share the same pad. so from ur info it shall be same with vr4 too.
amrancharger
779
96
may i know y TS wanna change brake?
not powerful enuf?for looks?or just want to spend excess money? :smokin:
New should be above the RM300 region. Yup, VR4 and Pajero V6 same pads.....
---------- Post added at 09:47 PM ---------- 6 hour anti-bump limit - Previous post was at 09:46 PM ----------
Upgrade brakes should be for better braking, for looks can fit Brembo Cover.....hahahaha:rofl:
katz79
45
2
1,508
most of persona user over the net complained the poor brakes performance especially from b line model. the spongy effect makes them feel insecure.
csl
1,285
498
1,683
Malysia
halfcut brembo front + rear cost RM2k+
Custom bracket + installation RM500
Hey there,
Thinking of upgrading my cams to matspeed, but don't know which degree to use.
Matspeed regrind camshaft 272/280/282/288 degree ?
My current engine setup
Currently using hotbits 4-2-1, 2 inch pipe with bullet and s-flow.
Will change my s-flow to hotbits back box.
iridium spark plugs
drop-in wire mesh intake
safc neo
Thanks in advance.:biggrin:
