changing brake system
hardcorecar
77
Sabah
wanna you guys out there...i wanna change my stock brake to new level soo how do i achieve it???plz help me out...:itsme:
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
u can:
change to better brake pad.
bleed n changed brake oil to new fresh oil.
fit bigger servo n pump.
Maxx
2,072
42
5,148
PD-Putrajaya-KL
no need change rotor if ur rotor still good n thick.
but if u want slotted/crossdrill, u can buy aftermarket n change..
Whats your budget? If you got a big budget consider changing the master cylinder pump and go for 4-pot brakes
Many things can do, from pump, vacuum servo, disc rotor, drilled/slotted, brakes pads, caliper and so on....
go for 4 pot nissan or mitsubishi. but nissan cheaper & i heard bites more than mitsu ones.
I think depends on the mod. I remember my friend fitted Bigger brake from GTR into his SSS, say not too good...My Mitsu now better bite with Trestor Blue advantage over Bendix Metal King Titanium...
l2s_turbo
1,068
154
You can think of toyota 4 pot also, just fitted to my suzuki swift..
ronaldindin
207
29
www.12bet.com
I'm thinking of changing my brake pad to ceramic type. Some user commented that it'll produce some funny sound after long time of usage. please advise
katz79
45
2
1,508
u can choose evo 3 twin pot. plug n play but must use evo lower arm.
Need help and guidance....brought the car to dunlop klinikcar...and the mechanic told me dat the whole transmission need to change including the gears+torque converter.....wad is see is the AFT leak from the engine's flywheel side ..in between the transmission...does the damage torque converter will effect the gears?....bcoz i felt my gear are still in good condition....
