changing brake system
hardcorecar
77
Sabah
wanna you guys out there...i wanna change my stock brake to new level soo how do i achieve it???plz help me out...:itsme:
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
u can:
change to better brake pad.
bleed n changed brake oil to new fresh oil.
fit bigger servo n pump.
Maxx
2,072
42
5,148
PD-Putrajaya-KL
no need change rotor if ur rotor still good n thick.
but if u want slotted/crossdrill, u can buy aftermarket n change..
Whats your budget? If you got a big budget consider changing the master cylinder pump and go for 4-pot brakes
Many things can do, from pump, vacuum servo, disc rotor, drilled/slotted, brakes pads, caliper and so on....
go for 4 pot nissan or mitsubishi. but nissan cheaper & i heard bites more than mitsu ones.
I think depends on the mod. I remember my friend fitted Bigger brake from GTR into his SSS, say not too good...My Mitsu now better bite with Trestor Blue advantage over Bendix Metal King Titanium...
l2s_turbo
1,068
154
You can think of toyota 4 pot also, just fitted to my suzuki swift..
ronaldindin
207
29
www.12bet.com
I'm thinking of changing my brake pad to ceramic type. Some user commented that it'll produce some funny sound after long time of usage. please advise
katz79
45
2
1,508
u can choose evo 3 twin pot. plug n play but must use evo lower arm.
Hi, I know theres is alot cars on the road facing same problem, the fan belt / aircond belt is making noise.
Mine happends after my mech change my timing belt :mad: it is damn annoying, no matter the engine is on idle or revving, it still making noise.
I called up the mech, he says just spray some lubs on the pully of the belt well after spray it just last 1 day then it comes again...i check on the belt, well it seems abit loosen coz can see it is fluctuating in spinning motion.
So is...
