PLS help me ! for levin supercharger owner
arrisonv67
Aug 22, 2011
6
Im hope can find some pro ppl at here to lead me modifield my toyota SE limited ...i now change levin supercharger already ...Now i wan to use ae101 DASHBOARD...i wana ask can i use supercharger with ae101 dashboard not ? wiring need to find not ? can got problem at the end not ? tq pls help me newbie guy ...
D7zul
2,697
848
Shah Alam
i think u can fit in AE92 Supercharger dashboard.. it's PnP & easier..
if AE101 dashboard, need a lil modification.. i think..
i've seen AE92 body with AE111 dashboard.. not a good fit.. but still can fit.. if u want..
need comments from other people who uses this setup
:biggrin:
arrisonv67
6
:biggrin:
i from kedah ....i saw many pomen lazy to fix my ae101 dashboard with supercharger engine ....so boring ....who can tell me whr to find pro pomen can fix it ...pls at kedah are so HARD..maybe kedah brain no good...
turbo10
626
47
3,028
sg petani kedah
Alo bro..if pomen lazy and you can't find any pomen to install for you don't simply say "maybe kedah brain no good" one...I am from Kedah and I can easily offended by your 'general' statement. Which part of Kedah bro? There are a few places that can do the retrofit, even LE can fit ae111 dash and I can assist you but now no minat already.
arrisonv67
6
sory bro ...i so confuse ...im from bedong ...can tell me whr to modi tis dashboard ? help me ...i found many pomen always ask me throw my car to river ...so shit thm..dunoe fix thn wan gv many many reason ...so fire u noe .
shamburke
2,244
12
Subang Jaya
u can use both 111 or even 101.. but need to mod the pillar inside the dashboard..
witing wise.. no problem.. but loads of work and adjustments
been using 101 dash since 1999 and even seen one with 111 dash!..
turbo10
626
47
3,028
sg petani kedah
ok ..no prob bro..later i pm u the number..1 shop is at Bedong, Ah Weng, the shop opposite the old school used car on the left side if you are heading to Alor Setar..in front of his shop got a stripped coupe Mazda RX3 and the other one is in Sungai Petani, or you can give a call to few friends of mine from Kelab Peminat Toyota Utara to ask them tips on how and where to install the ae101 into ae92..some of them have installed their halfcut dashboard (silvertop, blacktop) and looks good. but i think you should have the dashboard mount rail from halfcut and swap with your original one..not that simple work and most pomen will decline to do it..:bawling:
Mods if this is in wrong place please move to proper.
I have often wonder if this is possible and if it has been done.
There are many places which do not allow larger engine displacement, road txs, or whatever, this conversion sounds very logical, and I am pretty sure it has been done.
Thanks for any info.
