wira 1.6 auto convert to 1.6 manual
ealt
2,395
16
Just my 2 cent....you need to change the ecu also, coz the coding parameter is different for this two variant.Yes, it would worked but you will suffer the engine judder/oscillated.cheers...
tk2005takeru
148
KK
Therefore?? Still dun get it the ECU, why must it change?? Can it run on auto engine if the car convert to manual?
ealt
2,395
16
It is because of some coding inside the ECU are amend for auto transmission to read it.The engine still can running but the true performance of manual engine you will not get it for 100%.You will suffer the throttle proggresion when idle and so on when shift the gear....But it not too much...you will not feel it at the earlier stage,but you will feel it soon....sorry if i mistake about this....just my 2 cent.cheers
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
nope...
nothing will effect the engine running...
in fact...1.6 Autobox have its own ecu to run logic-processing (proton utilizing mitsu invecs tech)...
thus when removing the autobox and replaced with manual,the gearbox's ECU will be removed along with other autobox parts....and none will giving negative impact to the engine running with new manual box....
:hmmmm:
p/s:sorry for gali old thread but....since like the cases hanging around so i just gatal tangan to post here :burnout:
Shinjite
864
120
1,543
Klang
I changed mine as well back in Aug 2008
Auto maxed out 3rd gear at 185km/h (hitting limiter)
Once converted to manual, easily >200km/h and released around 15HP more at the wheels. That is a LOT O.O"
Mar 12, 2020
24
nope...
:hmmmm:
Even the wiring not need to be change...?
Kawan2. Tolong sebarkan, Wira putih dgn Evo3 bodykit JEL9661 dicuri malam tadi di area Mentari Sunway. Kalau jumpa, message atau sms saya, 0166581100 Tq.
Friends. Please spread. White Wira 1.8 turbo with Evo3 bodykit JEL9661 was stolen last night at Sunway Mentari area. Please contact me if it is seen anywhere. Sms 0166581100.
Your kind assistance is highly appreciated. Thank you very much.
