Wifi enabled car
idnawse
205
36
perak
Just wanna share my new and low cost diy.. :itsme:
Bought this mini portable 3g/4g wifi router and plan to fix permanently inside my cockpit
Next process, dismantle
Make a panel cover for coin drawer slot. Later will cut to make hole for USB port
Marking and cut the router housing.
https://fbcdn-sphotos-d-a.akamaihd....720/534171_10151718067239350_1126012454_n.jpg
Done stage 1
Checking the router after the fitting process .. green lit mean 3G is connected
Use this USB car adaptor for power source (5V 1A output)
Dismantling and rewiring process
Placing the power source inside the router. Extend the antenna (small white and black wire) for better TX/RX
Done..stage 2
Fit inside the coin drawer and wiring. Done. Just plug in USB broadband modem and enjoy wifi
Next plan will be transferring the status indicator using fibre optic cable coz the LED is very small and hard to relocate and solder.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
niceeeeee
idnawse
205
36
perak
Can the router handle the inconsistant power supply from the car?
Using in-car usb adaptor charger (use for charge tablet/handphone) board might not give problem coz it only use 5v 1000mA.
goohtj
57
12
5,008
nice diy.
for led you could use a normal size 3mm or 5mm and parallel / replace the existing one.
if for 5v power indicator you need a 100ohm resistor serie to the led.
idnawse
205
36
perak
Ya, plan like that before, but looking the pcb layout, not enuff expert to re-solder on tiny2 area like dat. What i mean is indicator for router (power on, wifi status, connecting status) not power status from switch to router.
I'm searching for my laptop that unfortunately some bugger stole.:angry_smile:
Would seriously appreciate anybody's generous help. I'll reward the person with a huge ang pow if I'm able to recover my laptop. :shocked:
The date in the laptop is seriously very important to me.
Stolen last Thursday (Jan 19th) near Carlos (Anggrik) Restorant USJ2... parked in Shell Station USJ2...
The details of my laptop:
DELL INSPIRON(TM) 6000 Intel(R) Pentium
Service Tag: CPNLF1S
A report has been made...
