Which trumpet length is the best to give more performance for 4age silvertop?
D7zul
2,697
848
Shah Alam
i think u should delete this thread n concentrate on d other thread u've posted
Instead of the conventional way of changing the boot by removing the whole driveshaft, and then whacking out the CV joint, I used a simpler way to get the boot onto the cv joint. Note: This method should only be used if you are sure the grease inside is still clean and the CV joint is still in good condition.
Steps:
1. Identify which boot has torn (normally it is outer boot)...
