What engine oil is the most suitable for your car??
ary4145
44
Engine oil... Haiyoo.. from mineral.. semi syntec.. full syntec.. 15w/50.. 20w/40.. n goes on.. but actually does anyone knows what is the actual suggested type of oil for the car?? .. for example if a 1.5wira - the suitable oil is 20w/50.. no matter what is the brand..
I hope that anyone could share some infomation on this issue.. As most of us only knows because our mech told us so.. but why must we use this type of oil..n not the other?
Thanks in advance
huakenny
LB Performance
9,126
240
Kota Kinabalu
coz some oil grade is too thin/thick...so not suitable for ur car...
wira use 10w40 is ok. 20w50 is ok but abit heavier compare to 10w40
synthetic based wil hv better protection compare to mineral typw...less friction, less heat...etc
my2cent
ary4145
44
my2cent
If so, what car or CC is suitable for a kancil for example? 10w/40? A heavier grade is suitable for what car (ie in what range of cc? ). if a 4g91 uses a heavier grade oil what will happen.. and if uses a thinner what will happen? so, is there a spesific range or just 'hantam".. when changing oil..
huakenny
LB Performance
9,126
240
Kota Kinabalu
kancil 5w30 or 10w30....
use heavier =loss power , high fc...etc
use too thin....engine oil will gone in few days (depends)....mean too thin for ur ride..
owes check ur car manual for coorect oil grade, or refer to ur mech to confirm....
turbo cars cannot use 5w30 or 10w30....need hiugher grade.....
try to google the info to know more
silverwave
141
my2cent
for proton cars, is it better to use full synthetic or semi-synthetic? could u recommend some good engine oils too? for 10w-40
huakenny
LB Performance
9,126
240
Kota Kinabalu
10w40...i will suggested Q8 coz it will reduce/eliminate ur tappet sound...
my fren n my kenari is using Royal Purple.....his wira tappet sound is noticeable....my kenari engine sound is rough...
wit Q8, it perform better...
u can try other brands as well, i juz gv u some ideas....
:_:
silverwave
141
:_:
Q8 is full synthetic or semi? may i know the price?
NeoG
96
Hi
I driving Honda Civic 1.6 (A) 11years old car and non-Vtec. currently i was using Castrol Manegtec 10w-40. can someone give me some idea do i using the right oil? and i heard Idemitsu is good for Honda car but it slightly expensive compare to Castrol. I buy Castrol at RM78. Please advice
TQ... ^_^y
smartgen2
121
For proton, try not to use fully syn that is too thin oil as the engine oil will escape into combusion chamber and some come out from the top gasket. The lowest should be 10w/40.
NeoG
96
if not mistaken is Mineral Based, btw is Q8 oils suituable for my Civic?
NeoG
96
Q8 have any better/avantage compare to Castrol Magentic & the Idemitsu oils? pls advise :)
huakenny
LB Performance
9,126
240
Kota Kinabalu
u ask me this question...i dunno how to answer u coz im not the manufacturer...
as a user, wat i can suggest u is give it a trial... no harm
if u wanna stick back to ur own brand after tested Q8, u can stick back. no problem...
wat i know is Q8 can eliminate my car tappet sound, while other brands canot. even yes, maybe i hvnt discover yet. tat y im using Q8
Dear forumer,
I just bought 2nd hand intake velocity. But the inlet hose has bend and almost broken due to poor shipping. Where the workshop in klang valley can repair? since it is aloi@aluminium material.broken heart when see the damaged.
