Waja 2001 standard to modify
thomzcruz80
Oct 1, 2011
508
Kuching
My ride,Waja 1st model sohc still in good running (engine). I intend to convert to GSR or Mivec but still sayang my engine still move smoothly can reach 160rpm (auto).
How bout if i juz upgrade adjustable cam pulley,crank pulley and cam shaft?
How bout oil consumption? HP? Any opinion guys?
mant53
13
2
1,503
you mean 160km/h??
what u intend to do with ur car?? high revving all the time?
high cams will give more power but ur low end would be a bit sluggish...
to me, when u use high cams, u'll be more on higher rpm.. so higher rpm, higher fuel consumption...
p/s: correct me if i'm wrong.. :)
ehdrian
I Don't Care!
3,310
280
1,683
wat is ur targetted hp?..wat is ur budget?..
thomzcruz80
508
Kuching
Mant53: Wat i mean is even my engine stock no modification,it can reach 160. That bcoz i not cancel to upgrade gsr o mivec engine.
ehdrian: No target ast ol bro...juz wana powerful engine. Surveying recond engine but mine still ok. So,tryin to upgrade high cam,cam pulley n crank pulley...
mines998
1,048
149
If no target is difficult for people to give you advice...what is consider powerful engine to you?
thomzcruz80
508
Kuching
Power engine 4 me is more power than my old stock engine. Just for daily use...not race. Stable engine i mean.
---------- Post added at 10:01 PM ---------- 6 hour anti-bump limit - Previous post was at 09:57 PM ----------
convert to manual. sure can bypass 160km/h.
Yup.gud idea..shiftronic?
arrowhead
4,621
152
5,163
Damansara/PJ
i think manual would be more responsive, nv tried the tiptronic before tho. no comments on that
ehdrian
I Don't Care!
3,310
280
1,683
TS got very low expectation only, easy la..
aHLengChai
380
53
no target?
then upgrade intake & exhaust enough..
to make the engine run more smoother..
agreed.. just do standart modification la bro..
extractor..muffler.. center bullet.. manual trans..lighten flywheel..lighten rims..lighten body(cf)..lighten..ecu management blablabla..still reliable to daily drive..:biggrin:
lameshit
Sep 17, 2011
45
4
508
Johor Bahru
Saving on your bucks? Try to high cam your pistons
And change th exhaust intake 421, provide you with sufficient power as well as efficiency
I have a problem with my car..When i on the air-con,the timing of the car will become very low.I've adjust the timing and now the problem is the opposite where the timing will be very high when i off the air-con..is it because of the car voltage??does fixing volt stabilizer will help??btw,do mounting problem cause this prob??
i need some assistance...thanks in advance.....
