Video: 2020 Honda City RS i-MMD first look
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
yea i get that, what i mean is, at lower gears, our torque is 'multiplied'.... without a gearbox what you have is one ratio
what im assuming is, if it has even a 3 or even 2 speed it would be able to accelerate faster (theoretically?)
only strange thing (from what i have read) is that the electric motor and ice doesnt seem to be able to run at the same time
electric motor working speed range don't need gearbox, you use an inverter to control it, in the city i believe it is also the same working method, the accelerator is like the adjuster knob for speed modulation, then the ECU tells the electric motor to speed up or slow down. Much like how we play with the speed variation of an electric motor via an inverter. The best example is electric forklift. You can cap the max speed or the electric motor or you can crank it up to the max.
Putting a 3 or 2 speed gearbox for the electric motor is redundant and it adds weights and also power lost.
sweelt
Nov 6, 2016
2,306
248
663
Penang
inverter drive make sense to me. Been puzzling me too like bro @lsm1991
factory using lots of inverter to control pump flowrate (can read motor rpm, frequency, amps..etc)
lsm1991
1,469
185
PJ
hmmm have alot ot understand bout electric motors
TitanRev
Mar 3, 2005
8,180
3,678
Yes, its easy you make changes at the inverter simple also. It also saves electric during motor start up as you don't get spikes
TitanRev
Mar 3, 2005
8,180
3,678
The PCU (Power Control Unit) is the inverter in case of the city. The electric motor itself is just a motor, is the ECU and PCU are the brains that does all the signal receiving, calculation, controls, communications and send signal out to the electric motors, engines, clutch mechanism on what to do and when to do it.
Tom
TIMETOATTACK
5,562
3,229
This City don't need a gearbox coz the wheels are driven by electric motor and has no connection with the engine. The engine only has a single ratio 1:1 when it cuts in to help during the high speed mode. Correct me if im wrong. There's only a mechanism to make the connections switch between the wheels and electric motors and engine. Even for this city the Reverse is powered by the electric motor also.
yeah after some research, the immd system is indeed very next gen.
To understand the immd and the no transmission idea, one must not assume it to be a regular hybrid car. it's quite the opposite, at least mostly when driven in the city.
here are my findings, which i hope will make it easy for all to understand
- It is more like an electric car with a petrol engine
- the petrol engine assists the electric drive
- the petrol engine runs in the background until car hit highway speeds
- Motor 1 does the regen like an alternator
- Motor 2 drive the wheels
- The petrol engine runs to either, or at the same time:
- - power motor 1, to charge battery, to power motor 2, to drive the front wheels
- - kick in at highway speeds
- there's no transmission because:
- - the car is driven primarily by an electric motor
- - the engine runs at a constant 6th gear metaphorically
Not sure if the upcoming Honda City immd's version matches but I found this video very helpful, it's not on the 1.5L immd specifically but provides a good idea
TitanRev
Mar 3, 2005
8,180
3,678
Yup, honda make it a bit simpler for the mass to understand so that it doesn't sound so confusing to them so they still called the gear mechanism e-cvt. In the ads and the much spoken 253Nm is actually the torque generated by the electric motor and it has a small workable range for low speed. Much like short burst of power to get things moving up to speed a bit quicker.
lsm1991
1,469
185
PJ
hmm did some homework... ur right... end of the day they dont really need a gearbox...
ixeo
4,788
3,080
KL, Malaysia
My question is, what’s the warranty on this? If ANYTHING goes wrong, you’ll have to pay Honda Malaysia prices for this out of warranty.
5 years, ok fine. 8 years would be amazing and a winner. Then there’s the price. If it’s much higher than the current full spec City, I’ll rather use the same amount of money to get the X70. Get more car for the money.
minibeany
598
102
543
more electrical parts will be costly to fix. I don't think any outside mechanic can fix it... then, this car has to pakai buang like our other home electrical products.
TitanRev
Mar 3, 2005
8,180
3,678
I think in this city case, probably the bearings on the electric motors, the clutch packs for the direct drive switch gear for the switching mechanism, the batteries but since it's a Li battery it will be better than the older batteries used in older hybrid, and the usual engine parts
Let's wait and see how things unfold
Still can repair, but by changing parts as a whole, like whole motor, whole this and that.......haha
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
I would treat cars with such tech like a premium brand front load washing machine. The motor that turns the drums, belting, body, doors, power cords, soap/detergent loader will definitely last.
What dont last is the control board...and cost a bomb to replace.
Batteries definitely needs to be replaced at certain point and the cost is key.
Remember our younger days playing with battery powered RC cars? One day it just stopped running even when the motor is still fine if we test it and we replaces the battery. We just cant figure out whats wrong and just throw it away.
Still, i would love to own a Tesla if i can afford it.
  • Like
Reactions: Izso and Tom
i just bought a rear set of TRD adjustable absorber(dark blue) from someone.
I have checked properly b4 i installed it to my car (No leaking and condition ok) but once installed, got some weird sound from the right side..like Kook Koook especially the road is rough. Anyone faced this problem b4? very headache.:mad:
