Turbokits 660 help =(
TurboHolic
5
Sabah
im using turbokits for my 660 kancil , but when long distance , at 4th gear 100kmh , it starts to jerking , fuel not enough =( , my fren ask me to korek the ic pump / fuel pump , anyone can teach me =) , i still cant afford injection so im sticking to use turbokits till nxt year =(
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
ok, to understand better.... you're using standard 660cc carb perodua engine right?
the turbo kit does not come wif it's own fuel pump? AFAIK, to turbocharge a carbie you need a decent fuel pump & a adj fuel pressure regulator..
...I'm no expert... but that what i read... maybe need to wait for carbie turbo otais to come in first
TurboHolic
5
Sabah
im using 6valve head , stock head , n stock fuel / ic pump , em , my turbo kit does not come with it's own fuel pump .. what kind of fuel pump n fuel regulator should i use .. carb can u fuel regulator ?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
TurboHolic
5
Sabah
From what I read here How to Add a Turbo Charger to a Carbureted Engine | eHow.com, it seem it need one...
As I say before, I'm no carb turbo sifu... maybe you could source early Mira L2 pump and regulator?
em , from what i read from ur posted link , yeah , i do need regulator and fuel pump i guess .. regulator easy to find just , the fuel pump .. should i use mira L2 stock fuel tank with pump that , or external one , emm , looking foward for reply from carbie sifuu .
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
i think L2 pump should do it,... the adj fuel regulator is needed to ensure 1:1 ratio between boost and fuel pressure... well, at least that what the article says la...
better wait for sifus to show up
TurboHolic
5
Sabah
btw what is the real function of that fuel reg ? control the fuel supply ?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
from what i know....fuel pump would pump at the highest possible pressure it could pump...
if 150liter/hour@8bar of pressure then surely u need the regulator to control the pressure at acceptable level....
thats the function of fuel regulator... :adore:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
finally.... :adore:
TurboHolic
5
Sabah
ya finally , will it solve my jerking problem if im using external fuel pump n fuel regulator ? plz plz help =)
The Marketplace Top Posts
Today we will be sharing with you a not very luxurious car but a normal Jazz Hybrid. We have no prejudice in cars, brands, sizes, or colours. As long you love your ride, want it to be protected, we will handle it for you. We arrived to this Jazz Hybrid early in the morning, when you can barely see the sun. It had been drizzling since 6am but fortunately it stopped...
