Turbokits 660 help =(
TurboHolic
5
Sabah
im using turbokits for my 660 kancil , but when long distance , at 4th gear 100kmh , it starts to jerking , fuel not enough =( , my fren ask me to korek the ic pump / fuel pump , anyone can teach me =) , i still cant afford injection so im sticking to use turbokits till nxt year =(
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
ok, to understand better.... you're using standard 660cc carb perodua engine right?
the turbo kit does not come wif it's own fuel pump? AFAIK, to turbocharge a carbie you need a decent fuel pump & a adj fuel pressure regulator..
...I'm no expert... but that what i read... maybe need to wait for carbie turbo otais to come in first
TurboHolic
5
Sabah
im using 6valve head , stock head , n stock fuel / ic pump , em , my turbo kit does not come with it's own fuel pump .. what kind of fuel pump n fuel regulator should i use .. carb can u fuel regulator ?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
TurboHolic
5
Sabah
From what I read here How to Add a Turbo Charger to a Carbureted Engine | eHow.com, it seem it need one...
As I say before, I'm no carb turbo sifu... maybe you could source early Mira L2 pump and regulator?
em , from what i read from ur posted link , yeah , i do need regulator and fuel pump i guess .. regulator easy to find just , the fuel pump .. should i use mira L2 stock fuel tank with pump that , or external one , emm , looking foward for reply from carbie sifuu .
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
i think L2 pump should do it,... the adj fuel regulator is needed to ensure 1:1 ratio between boost and fuel pressure... well, at least that what the article says la...
better wait for sifus to show up
TurboHolic
5
Sabah
btw what is the real function of that fuel reg ? control the fuel supply ?
from what i know....fuel pump would pump at the highest possible pressure it could pump...
if 150liter/hour@8bar of pressure then surely u need the regulator to control the pressure at acceptable level....
thats the function of fuel regulator... :adore:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
finally.... :adore:
TurboHolic
5
Sabah
ya finally , will it solve my jerking problem if im using external fuel pump n fuel regulator ? plz plz help =)
hi,
i've been told that 4G63t from evo 1-3 (some say 2G block??) are prone to crack which is not good for high hp application.
yeah i know that evo 3 is a bit high compression..but if change to forged low compression piston but other's like block, conrod, crank, bearing and so on still stock...how many torque/hp is the max before damage ?
ok, after that some people told me..the piston is ok (except for high comp evo 3), but the conrod is sooo weak.
now, if change piston+conrod..and...
