Tires suggestion for 195/55/15
ixeo
4,788
3,080
KL, Malaysia
I've used the ABS several times, I can confirm it works and its useful in a front wheel drive car.
Rear wheel drive i don't dare to try.
sanekit
Dec 9, 2015
1,616
157
663
Aku Brake Sendiri?
yass. but sometimes kaki banyak berat locked-up terus. ahahaha. but that was when i was using stock 4g15 servo, master pump and caliper. now after swap engine to 4g9x, servo and master using evo3, front caliper from 93T no more having brake locked up issue.
that's make it more fun without all the new technologies. :-) like the other post... slow car drive fast vs fast car drive fast... hehehe....
it's not fun when u are sliding on all 4 tyres. LOL
parakey
1,367
226
663
I wonder if it's possible to retro fit abs on your car from halfcut parts. My wira 1.8 comes standard with it
  • Like
Reactions: sanekit
ixeo
4,788
3,080
KL, Malaysia
ABS possible to be retro-fitted from Japan Passo 1.3L half cut into Myvi 1.0L
So I believe if the whole thing including the ECU is transplanted in, confirm works.
kaihoong
93
8
28
Penang
Now I also using double layer servo pump but duno from which car, I still not feel very soft when press. Any type of pump recommend?
Without ABS don't over do your brakes, meaning make it too strong. In panic situation especially like corners, if brakes lock sure will slide away......
  • Like
Reactions: sanekit
sanekit
Dec 9, 2015
1,616
157
663
yes. just need to get the ECU, the ABS unit and all from the right model/year lancer/mirage. haha. my halfcut engine was from a 1994 mirage that doesnt have ABS or cruise control etc. your car is C99 ah? damn nice laa. not swiss cheese chassis like my C97.
how do u describe the soft? is it sunk in too deep? if so, u can adjust that at the pedal there to make the pedal travel shorter or longer. for master pump, u can try the evo pump. stock 1.5 wira pump is small but it should be a good grip with the double layer servo. but the evo pump feels for firm.
Can play with top master pump bore size also
  • Like
Reactions: sanekit
Hi friends, wanna sort out is the Ferrari F355 maintainance is bad?
I mean, I know I shouldnt ask about that as it was a Ferrari. But what about parts?
Im thinkin about it since I saw one adv at Mudah selling around 2xx K which is I guess affordable ferrari w best look.
Anyone owned it before can give some points and good about it?
No harm !
:wavey:
