timing tune with reset ecu
boyzone
2,669
hi, guys..
I will change my throttle body from 50mm to 54mm soon, so after I install , should I need to reset ecu/ grounded ecu to retune back my timing and ignition ?? how to grounded my ecu ??
pls advice .. Thanks :D
ehaab
964
Malaysia
if u just want to reset the ECU..just disconnect the battery for a few hours...then plug it back..shuld do the job...
boyzone
2,669
That's reset ecu only, if I want to check/tune my ignition timing, should I grounded my ecu ??
boyzone
2,669
so after I setting everythings, if one day I gonna to change battery, that's mean I still need to re tune back everythings ??pls advice :D
boyzone
2,669
ecu will only fully reset when u unplug battery for 8hrs .. this I know :D
No, we're not referring to the BMW 328 as seen in the E36 and E46 generations. This is way before it. BMW is paying its tribute to the first sports cars in its portfolio. Made in the 1930s, the BMW 328 was equilavent to the BMW Z8 in modern days. The BMW 328 Hommage is built to identical looks to the older car, however its lightweight philosophy has been enchanced with the use of Carbon Fibre plastics as...
