timing tune with reset ecu
boyzone
2,669
38
5,148
hi, guys..
I will change my throttle body from 50mm to 54mm soon, so after I install , should I need to reset ecu/ grounded ecu to retune back my timing and ignition ?? how to grounded my ecu ??
pls advice .. Thanks :D
ehaab
964
Malaysia
if u just want to reset the ECU..just disconnect the battery for a few hours...then plug it back..shuld do the job...
boyzone
2,669
38
5,148
That's reset ecu only, if I want to check/tune my ignition timing, should I grounded my ecu ??
boyzone
2,669
38
5,148
so after I setting everythings, if one day I gonna to change battery, that's mean I still need to re tune back everythings ??pls advice :D
boyzone
2,669
38
5,148
ecu will only fully reset when u unplug battery for 8hrs .. this I know :D
Hi all,
I don't know how to explain this but I feel that my 4 wheels like went in abit .. that makes my car look abit weird .. the other day I park my car at somewhere beside there is a Wira .. I check his wheels and mine his of course look better and fierce .. because his wheels fit perfectly .. why is this? Different absorbers & springs combination different result? I also saw some satrias same as mine. I never done before any screw setting becos my front don't come with the screw.
can...
