Suspension setup question...
aycy
Penang / Butterworth
Hi guys. I was wondering which adjustable setup work the best on highway high speed cruising?
Should we set front sus harder or the back harder? My is on m7 adjustable. Does not have any info for the spring rate.
Setup for ct9a ix. Hope to get some info from u guys...
like me..i use tein HA..for corolla..spring rate is 8kg front,6.5kg rear..front setup is more harder than rear..coz,the engine weight..
---------- Post added at 10:04 PM ---------- 6 hour anti-bump limit - Previous post was at 10:02 PM ----------
it depend on your comfortness...if ur adjustable got soft/hard...use it..and compare it by trying every level until u r satisfied..
may i know how high is the high speed you were defining? and which part of malaysia's highway you were cruising normally?
I think for highway u should set it as hard as u can both rear and front(means how bumpy and back pain u can handle) as u are not going to corner that much, set it to understeer a bit cause oversteer is dangerous in high speed, but when setting the suspension as hard as possible u should also take into consideration of our weather as to get more grip on wet surface u need softer setting, and since u are talking about highway speed bump and pothole should not come into consideration. and make it as low as u can as it would be more stable.
Third world highways - there's bound to be bumps and maybe potholes too, so make sure you don't overpressure your tyres.
Otherwise hitting a bump at 180kmh with stiff suspension/tyres can be nerve wrecking.
my adjustable is soft/hard. so normally is suspension front set harder then the back?
PLUS highway mostly. 180-200km/h cruising. actually i was confused, should the back softer or the front? diff ppl tell me diff story. so just ask other evo taiko here see what is their settings.
car already quite low. how to know its a understeer or oversteer settings?
will check on that...
Bro aycy I m getting the m7 suspension as well to replace the stock bilsteins. So far any comment from you? Cornering stability?driving comfort?
180km/h cruising wowwww u r burning a lot of Ron 97 there haha. What's the milage with that speed?
For 140 - 160km/h cruise I m getting 420km
Anyone tried the custom suspension setup from RCS (Radical Chassis Solutions) in Sunway? Especially for evo?
https://www.facebook.com/group.php?gid=152209335732
Last week pangyau n myself met with Nandakumar from RCS to discuss reg the best street / track suspension set up for evo.
I think you have to visit this RCS and joyride one of the customer's car (if available) to feel it yourself.
compare to the tein monoflex, the different is like day and night..
the only downside i can see is, your evo has to be on the standard ride height for maximize the custom setup of this suspension.
erm try google understeer and oversteer to understand a bit about them. Then u can set it to understeer or oversteer.
Yea ur right, but he didnt mention about comfort and regardless of our highway condition he said best for highway high speed cruising. so thats the best option. if not go for milder setting, but still maintain the lowest possible ride height and the hardest spring rate u can humanly handle on our road. and the suspension stiffness and height for front and back should be almost level as u dont want it to be too vary as it could result in excessive understeer or oversteer. and im saying this without taking into account of our road condtion, but if u stick to the highway and u can handle the uncomfortable of the ride that would probably cause u head and back pain than go ahead with it.
Green mivec: im getting about 380-400km for full tank on highway. M7 is just like superstreet tein. Not bad.
R11: sound like not bad the RCS thing. U mean the custom spring for our stock suspension? Standred car height is my problem. I like it to be low.
Luqae: roger that...
its not just the spring, but the shock abs and the front camber adjuster as well. they will re-use the OEM suspension top mount.
they can make it low, not a problem, but this will reduce the suspension's performance and ride comfort. They also can customize the suspension for track purpose only, but are not recommended for street / daily driving.
TBH, I'm quite impress after the joyride, and I suggest that you should try the same..
i am using monoflex, and cusco anti-roll bar, yes, very stiff drive. but i love it. haha
the front pillow ball gives "metal squeezing" sound after i use it for a year (even i very seldom drive the car). that is really irritating sound, tak boleh tahan.
then, i use back the original front top mount. no more sound, and it soften the ride, a bit more comforable. very nice.
but now can only adjust the front chamber using the original chamber nut, either 1.5 deg or 2.5 deg (if i remember right) . so far so good.
Adjusting your suspension is not only the matter of soft and hard only.
The important thing is the damping ratio you get.
I don't think you will enjoy a ride back from Penang to JB if yr car is bouncing when ever there is a uneven surface right?
Adjusting on harder side is always good if you're going for track or touge run.
Our evo has a very good down force and the traction is good enough for normal setting on highway.
I used b4 Tanabe,HKS and Ohlin. The best on highway still blistein. Y? cause adjustable racing suspension are not made for highway use. For track i will definitely choose adjustable.
Hi guys... sorry reviving the old thread.
I need an assistance to guide me getting the coilover.
At the moment, existing Bilstein probably to give way soon and need replacement.
Refurbishing the Bilstein seems out of the equation.
Getting 2nd/used parts also not very much into the account.
As the refurbishment/maintenance very much not practical in cost matters.
At the moment Tein Street Advance & Tein Street Flex seems caught my intention.
Since the Tein Super Street no longer in production, so left me with this choice only.
The car rarely driven but I will drive daily if I has a chance.
I look forward something comfortable but firms.
Anybody input very much appreciated.
i think for local serviceable have 3 option Titan, Claws advanced suspension, F-Tune racing. Titan & F-Tune racing use Torco oil in their shock.
all 3 can do mono invert tube setup.
Go test their demo car... you will like it...
xbalance2002,
Their price very competitive or closer with TEIN product.
Further more their product not coated with TUV etc.
Probably will exposed to corrosion in long run.
Fine tuning of each coilover by them cant be done.
As the car in Sabah & very much impossible for it.
xbalance2002,
yes price is close to TEIN but which range offer by TEIN.
i'm in manufacturing industrial TUV is just a cert, for powder coating i cant comment much.
been using Titan for 4 year now so far dint have any corrosion spot found....
Getting it fine tune is not easy, find balance between compress & rebound setting...
