Suitable fuel pump for 4G93T GSR
oneGSR
703
Ampang
www.zerotohundred.com
Hello, there... I need info:
any suitable fuel pump for GSR? For support boost 1.0 - 1.2. Standard fuel pump cannot support maa. Except branded aftermarket like walbro, sard and mores.
thanx...:)
speedz1665
612
i'm using SARD 235 lph on my gsr...so far no issues...fueling also cukup
bought for RM650 at SS racing
MitonCT26
1,112
9
Seremban
enough...unless you say you want to boost 2 bar then lain cerita la. :p
hamsap
1,524
PJ/ KL
thanx...:)
If my memory serves me right, original 4G93T comes with a rated 80lph fuel pump, which happens to be the same as EVO 1 items.. so i guess it should be quite sufficient in supplying enough velocity of fuel when boosting at 1 - 1.2 bar..
If not, let me know. Then I might want to change mine too :P
khoyos
2,632
156
5,163
Shah Alam
i'm using 2 units bosch 910 external pump. so far so good. tested until 2 bar, still got enough fuel supply.
The Marketplace Top Posts
Hey guys , im in need of advice here , the current NS40 battery in my Myvi is getting weaker ,thinking of upgrading it to a larger one which is NS60/L ,what i need to do/mod to get NS60 in there ?
The reason that i wanna upgrade the size is every year or so i require to replace the battery , everytime is the electrolyte inside dried out no matter i use the MF one or the normal one ,normal one after few weeks can see the electrolyte decreasing at a rapid rate already .
Which one is...
