Change injector and fuel pump for better top end power(NA setup)
hazz-one
Apr 19, 2014
11
503
hi im newbie driving Viva 850 mild mod.
Love to track at Sepang and join local event time attack.
Spec:
light crank pulley
Adj cam pulley
Hotbits 3-1
KnN open pod
Denso Ir plugs
Oli cooler
full ultra racing bars
passo caliper with AR rotor
Pro Rs hoses
ATR k-sport tyres
So far response is ok but i need a little more for my top end power
i know using light pulley and adv timing will provide good respond
but lack in top end power.
so far on straight line at Sepang i can do 140km/h :bawling:
Aiming for 160km/h at least:driver:
Some mech advised me to change a slightly bigger injector
stock 175cc change to MDH 210cc
Its that method works:hmmmm: coz stock injector cant support when high reving:hmmmm:
If i change the injector. should i change the fuel pump:hmmmm:
I dont mind to change the fuel pump to Walbro since in future i want BOT.
Tq....:proud:
May 8, 2012
4
503
jb
HI, for my personal advice is if u going to change the injector,do u hv any piggyback(EMU/Unichip) or something
that can use for tuning ur car's ECU? if no,then that is meaningless to change the injector.
bigger injector doesn't means the fuel can be pump more bcs u dun hv the piggyback to tell ur car's ECU what it should do.
Having bigger injectors but not having the means to control them is pointless. Are you using a AFPR?
4gbanger
1,958
386
1,683
Johor/ShahAlam
get at least SAFC or better e-manage then plonk in the injectors and fuel pump. no need to use walbro since its too big u not going to set 2 bar of boost later. get gsr or rb20 pump instead is more than enuf. port & polishing head also can improve ur power.
hazz-one
11
503
tq for the info...:burnout:
Im planning to BOT in the future target about 160hp from the engine.
Of coz after replacing stock bottom end.
e-manage is sufficient enough...:confused:
or straight away go standalone ecu like haltech.
Just in case to push up 2.0 bar...
And one more, most modern car right now dont have fuel return setup.
Do i need to change that or just replacing a bigger fuel pump is enough.
Ok for time being maybe go for PnP.
Normally for 3 cly head how much does it cost:confused:
Tq u guys...
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
Tq u guys...
Holy shit. Is that really possible for 850cc?
Even Campro BOT can get 180 max. Normally 160++ I've seen.
:adore:
hazz-one
11
503
yes it's possible but need to change bottom end.
Planning to change conrod to H-beam type.
Rebore to 73mm using nissan march piston.
I have seen viva bot pushing 175hp boosting at 1.8 bar..:driver:
But now want push the NA engine first after that BOT:proud:
4gbanger
1,958
386
1,683
Johor/ShahAlam
is that viva 1.0 or 850? 175hp is possible if 1.8bar to 2bar. but that type of tuning sure cannot go for track racing/time attack. thats only for drag since the cylinder block is bored to fit 73mm piston. normally track racer tune using 72mm piston to maintain cylinder block heat dissipation.
---------- Post added at 03:58 PM ---------- 6 hour anti-bump limit - Previous post was at 03:54 PM ----------
and if i have a lot of cash like u, i would definitely get and tune up turbo EF or JB engine.. or maybe get a 1.0 kelisa engine mix with EF-JL head + motec. result is much more better and more reliable than mod 850 engine..:smokin:
---------- Post added at 04:02 PM ---------- 6 hour anti-bump limit - Previous post was at 03:58 PM ----------
:adore:
campro BOT cant push high boost. it need to change the internal parts to achieve high boost.
hazz-one
11
503
Its viva 1.0 pushing 175hp.
I see... so can i use 72mm yrv piston or
or use l2 68mm piston for track purpose???
I still want to use the engine block with the ddvt head.
Dont want JPJ kacau he..he..
Worst case i can use kelisa block instead.
My target is wanna have K-car for track that is reliable and fun.
So not aiming high power. At lease can tapau satria neo cps standard he..he..
Reliable meaning i dont mind to spend more to upgrade
h-beam rod
Walboro pump
Haltec ecu
Clutch loceng
Etc....
Do the right thing at the first time..
Im not rushing.
Love to modified slowly.
4gbanger
1,958
386
1,683
Johor/ShahAlam
yrv or kelisa is a 72mm low compression suitable for turbo. can withstand up to 1.8 bar no problem n proven but MUST have enuff fuel delivery. if u really want to BOT ur 850 dvvt, need turbo engine internal as your stock internal are for N/A sure cannot withstand boost. and bare in mind, u gonna need alot of fund. and FYI, kelisa block is much more reliable since larger water jacket.
or i suggest u to get a kelisa engine, endorse it. then get a turbo head complete. u might save alot of cash + much more reliable engine.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
Yeah, i get it. I seen 0.7 bar max. Normally 0.5.
But viva? 1 liter less, that one is impressive.
And its alu or cast iron block?
Dude... not aiming high power and want to tapau a 1.6 Satria CPS? You'll need high power for that la.
And personally, I don't think there is such a thing as "fun" and "not high powered". :biggrin:
:top:
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
So since i have a kelisa, if I use EF-JL head + Motec, can gain a lot of improvement in performance and remain NA?
