Need sugestion for fuel pump n fuel regulator
Jeremy9544
Mar 16, 2014
26
Sarawak
Im running on a daihatsu L9 3 piston 660cc.. With a RHF4.. Any suggestion wat type/brand of fuel regulator n fuel pump should i use? Btw, im a newbie.. ;)
Jeremy9544
26
Sarawak
1 bar.. But nw i turned it to standard boost.. Because when i turned it to 1 bar, it seems the turbo is struggling to build pressure.. The boost meter is creeping slowly to 1 bar..
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
last time i use RB20DET fuel pump. its not a direct clip to stock fuel pump, but not much to mod. the size is bigger than stock but still can fit at the stock fuel bracket. some of my frens also use gsr fuel pump.. but not sure need to mod or not.. don't forget to get a fuel regulator as well before installing bigger fuel pump bro..
The iconic new Fiat 500 has taken the top spot in this year’s Car of The Year competition, winning the approval of 58 jury members from 22 countries.
Scoring 385 points, the Fiat beat the Mazda 2, which took second place with 325 votes, and the third-placed Ford Mondeo, which received 202 points.
Fourth went to the...
