spoiler led light repair?
Kyoichi(Emperor)
156
my wira aeroback factory spoiler led light doesn't seem to light up. How can I repair this?
Any suggestions? :frown:
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
return to EON factory... haha..
or try cabut the cover out and see if the whole LED panel detachable or not... if its detachable, try if u can detact the LED one by one... then u can change adi lo...
takumi86
150
Puchong
kyoici-san,
takumi here... hehehe ;)
i don think can replace wan,
normally people buy 3rd brake lite at acc shop.
simefly
449
check the other connection (especially the wire that run thru the boot to your spoiler) before dismantling the whole thing. Not advisable to 'cabut' the cover out though coz it has been ultrasonic sealed. It is rarely the fault of single LEDs that will result the whole thing malfunction.
Kyoichi(Emperor)
156
i hv checked. seems the connection is loose. i sambung it, and the leds did light up but it is dim. How to 'brigthen it'?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
waa... now light up adi wanna brighten it some more... its live good enough lo.. hahaha...
brighten it ar??... cannot i guess, unless u change to bigger LED... of u can polish the brake light surface and it crystal clear...
Kyoichi(Emperor)
156
coz the led is dim. at night, I test again.U know what I see? Those LEDs are blinking, their brightness kept changing ( dim,bright,dim, bright....) sort of signal style. How do I rectify this?
frcgrey
196
selangor
hey bro,
the L.E.D resistor spoiled already....replace it so that won't blinking and too dim....
as i know that wira below year 2001 only have this problem...
which year of your wira....?i mean the alphabets,not the year of manufactuar....
takumi86
150
Puchong
frcgrey said:
hey bro,
Waa.. good info.., explain a lilbit how to replace?
where to find this spoiled resisitor? :rolleyes:
frcgrey said:
hey bro,
alphabets?!?.. u mean the plate number ka?
Kyoichi(Emperor)
156
frcgrey said:
hey bro,
the year is hm...2000. How to replace the resistor?
takumi-kun, u seems to find this post interesting. hehehehehe :dancing2:
risyia
168
30
3,028
Pandan Indah
Bro,
Don't bother to take apart the LED to try to replace the resistors, it is to much of a hassle unless you are the DIY kind.
Also, don't bother to try to buy the LED set from Proton, I have enquired and it cost RM400 for a set.
The easiest solution which I did was to buy a complete spoiler with good condition LED from a half cut shop and replace the whole unit. It's a bonus if you can find a spoiler with the same colour as your car.
The one I bought cost about RM80.00.
Kyoichi(Emperor)
156
its kinda tough to find chop shop in my area. but i think ur solution is good, i am seriously considerating. Gotta look 4 a shop....gotta look.......thanks 4 the solution,risyia. I will try it.
lcchong
84
13
1,508
buy new one? then what the meaning of DIY ar? :confused:
Bump: buy new one? then what the meaning of DIY ar? :confused:
yyap2
1,146
well i chaned b4... normallay when it burn one led.. then 4 led will die together... mean u need to figur which led burn to get the other 3 led to on back... use a 3-5v battery and test eat battery..... then u found the burn one jus replace it.. then all will light up.....
but normally u also need to check ur resistor... 1 resistor = 4 led....
the hardest thing is removing the cover... remvoe the whole thing is easy but the cover is glue hard... u need a plastic cutter to cut the glue place... then only can remove... remember to glue back after done...
hey zth members..my 4g13 car emitted black smoke d. so sad...recently my radiator broke down and caused my gasket to collapsed and spilled black oil all over the place. costed me 400 to fix it :( . now got new probs..black smoke emitted during throttling... does it mean engine dah condemn? btw the fuel consumption is horrible . advise anyone?
