Senkyr Motorsports gives the 1 –Series the GTR race treatment
Dinesh
769
1,700
1,593
Yes people, it’s still a BMW 1-Series under all that awesomeness. Czech racing team, Senkyr Motorsports, has given the E82 1-Series the full-on race set-up, dubbed the 1-Series Coupe GTR.
If you find yourself thinking that it resembles an M3 GTR, you’re on the right path. The chassis was used to create a car similar to the Senkyr Motorsports E92 M3 GTR by adapting it for the wide body kit featured here.
Motivation for the car comes from the factory 3-liter twin-turbo straight six with a Senkyr intercooler up front for improved charge cooling. Total out put now hovers in the 402hp region, which coupled with the intense weight loss should see this thing make quick work of circuits.
Sending all that power to the rear wheels is a Holinger 6-speed sequential transmission. Bump and rebound is handled by a set of KW Competition 3-way coilovers with KW springs.
Filling out the wheel arches are BBS Motorsports 18x10 wheels up front and wider 18x12 rollers at the aft. The front wheels are wrapped in 270/650/R18 slicks while the rear gets 300/650/R18 for biting the asphalt.
Source: WorldCarFans
prince of speed
65
40
If you guys look carefully on the fourth picture, normally car will use strutbar above the suspension, but this car use diffrent equipment. Wonder what is that thing and what does it do....:confused:
faisal
1,864
54
The Valley
ignition.my
Are u referring to the black cylinder connected to the damper with a silver tube? that's the remote reservoir to adjust damping rate.
jackisblack
388
5
kuala lumpur
adf.ly
can't u see the full set rollcage????stiffness depends on what setup is the car use for..if the car don't have any strut bar...it doest mean that it is lame...just my2cent..
Hi all sifu-sifu,
As I know only waja, gen 2 and persona come with 4 engine mounting. So, may I know which is the best proton chassis to swap gsr turbo without any custom job just plug and play.
Thank you very much :)
