Question on 4G93T terbalik
C7950
15
Penang
Hi all sifu-sifu,
As I know only waja, gen 2 and persona come with 4 engine mounting. So, may I know which is the best proton chassis to swap gsr turbo without any custom job just plug and play.
Thank you very much :)
sweelt
Nov 6, 2016
2,306
248
663
Penang
Hi all sifu-sifu,
the 3 choice has good chassis. Up to you to choose.
sanekit
Dec 9, 2015
1,616
157
663
Hi all sifu-sifu,
persona chassis is better if u put in comparison from your list. avoid the GDi turbo if possible tho.
  • Like
Reactions: sweelt
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
persona chassis is a lot stiffer compare to gen2 and waja. u can test drive all 3 stock and compare. also coz persona is a lot newer than the others.
Furthermore, as per claimed by Proton Persona had better handlin 'layman term' than Waja. Not sure abt Gen Gen.
  • Like
Reactions: sanekit
Hi guys,
My car is currently having some problems after I changed from superstrut to adjustable absorbers.
The symptoms are:
1: Usually when I turn the steering wheel, it would return back. However when I fully turn the steering wheel, it won't return back to origin position.
2: Steering wheel vibrates when braking. Not so much when driving slowly. More so on high speed.
3: Steering wheel vibrates when over 130km/h.
After changing the absorbers, already done alignment. Is it...
