Satria Neo GSR swap
Toxique
67
508
Hello all sifu , may i ask , if i were to plonk in a GSR turbo/4g93t into my satria neo , must i also change the dashboard? If so , why?
Toxique
67
508
I think getting the engine endorsed isn't that much of an issue right now. Thanks anyway :)
Sent from my RM-821_apac_malaysia_316 using Tapatalk
ken yeang
6,000 RPM
6,617
1,327
if engine endorsement is not even an issue to you, then why concerned about dash in the 1st place:driver:?
123
2,007
23
better change because the dashboard is nicer than neo
Toxique
67
508
I would like to retain the neo ones if possible
---------- Post added at 10:53 PM ---------- 6 hour anti-bump limit - Previous post was at 10:50 PM ----------
Yeah... I'm concerned that i'll have to cut it down to make it fit and i like the neo dashboard more :D
Toxique
67
508
So must i change my dashboard or not? *confused* cause i see most SN with Mivec 1.6 change their dashboard, so i assume it's the same for GSR , no?
slipar
500
61
banting - pj
if dont want to change dashboard need to find good wireman to wired all the wiring to make the neo dashboard and all button function..if change dashboard for sure all thing sort out just plug the socket n the dashboard all function..
Hi, my car recently reach its 100k mark. Been a very good car, but the engine has a little noise and vibration lately. Just so happen i found a reasonable solution, and went to my local Tesco store and grab a bottle of Tufoil.
So here are a couple of question before using it,
1) Would 1 bottle be enough for my 2.4 liter engine?
2) Is there any Precautions before using?
3) Instead of using half a bottle for the subsequent change, could i use the whole bottle (silly question)...
