Satria Neo GSR swap
Toxique
67
508
Hello all sifu , may i ask , if i were to plonk in a GSR turbo/4g93t into my satria neo , must i also change the dashboard? If so , why?
Toxique
67
508
I think getting the engine endorsed isn't that much of an issue right now. Thanks anyway :)
Sent from my RM-821_apac_malaysia_316 using Tapatalk
ken yeang
6,617
1,327
if engine endorsement is not even an issue to you, then why concerned about dash in the 1st place:driver:?
123
2,007
23
better change because the dashboard is nicer than neo
Toxique
67
508
I would like to retain the neo ones if possible
---------- Post added at 10:53 PM ---------- 6 hour anti-bump limit - Previous post was at 10:50 PM ----------
Yeah... I'm concerned that i'll have to cut it down to make it fit and i like the neo dashboard more :D
Toxique
67
508
So must i change my dashboard or not? *confused* cause i see most SN with Mivec 1.6 change their dashboard, so i assume it's the same for GSR , no?
slipar
500
61
banting - pj
if dont want to change dashboard need to find good wireman to wired all the wiring to make the neo dashboard and all button function..if change dashboard for sure all thing sort out just plug the socket n the dashboard all function..
I have karcher k3.5 with karch snow foam lance 0.3l. The snow foam just too diluted. It cant cling on the dry surface of the car. Any idea to improve it to make it much thicker like car wash center?
