hi guys, this evening just install GSR's injectors in my 850T. but still dun have time to fit adj. fuel regulator. ehhh..have to custom made the tapak is it ?
ok..after install...i just change my SAFC setting to -ve side...more -ve. even at 800rpm at -30% !!!! the idle consider ok but not like previous one lah..still 1k++ rpm. and the exhaust note tooo much bass....sound like evo liao :lol:
800rpm and 2400rpm still ok for me...but for 4000rpm....i got a headache la. i set around -17% (can't remember the exact figure..just for referrence how low it is) and running gear 3 at 4000rpm at part throttle...ok for now. after that, i drive at FULL THROTTLE at instant kick from 4000rpm to 5000rpm++...knock occur a bit. krak krak krak...the from 5000rpm..slows down to 4000rpm and suddenly i shut off throttle..my car jerk just a little. ok..that's for 1st setting
after that..i try to retarding the ignition by adjusting the distributor a bit and set richer at 4000rpm setting with around -15% (1 teeth only). drive like previous run...from 4000rpm full throttle to 5000rpm ++...a little knock only. now i consider it ok if i set richer a bit at 4000rpm setting.
BUT...when slower down to 4000rpm and again suddenly shut off throttle...my car jerk a bit more than before
so my question is........is it normal for L2 with only on/off throttle sensor behave like that (sudden little jerk) when shut off throttle suddenly with big injectors ?
my theory is...when i go part throttle(sensor goes on throttle mode)...the engine goes a bit rich (maybe not) but when i off throttle (sensor goes off throttle mode), the engine goes suddenly lean...true or not ?
sifuuusssss helpppppp
