Rm8k Wira & Jazz GK5 ownership experience-A long way to go
minibeany
598
102
543
4 months. then change to samco. haha. i change it when i swap to double layer radiator. the previous single layer radiator from my 1.5 auto not that effective after swap to 93. my swap was not done properly btw. i did a lot of fixing and minor mods after the swap.
thinking of getting double layer too. Can I install the 1.6 wider radiator on a 1.5? will that has better cooling? cos I don't know what is the current condition of the fan and when they will break down :-)
parakey
1,367
226
663
i changed the ori black hose 4 years ago because the bypass pipe rust and about to leak. The current one didn't fail yet. Since I'm changing radiator may as well change the hose too. Easier to remember... old man problem. LoL.
Squeeze the hose. If still soft and supple, no need change.
lsm1991
1,469
185
PJ
Wanna ask anybody head of AMR500 supercharger?
My friend juz start to poison me to fit a supercharger.Hahahahahaha
What I go and research is these supercharger are universal and can fit different type of car.
Saw 1 on youtube in a 4g15 cab.
as good as worthless imo
leinnz
333
57
3,028
if letak supercharger, rod, piston need to be able to handle the load. also the block as well. correct me if im wrong?
  • Like
Reactions: Izso
lsm1991
1,469
185
PJ
make sure ade fuel....
rods just need to make sure can deal with the added stress... that tiny blower he mentioned, shouldnt be an issue. pistons, with the low boost i dont think compression needs to be reduced
as for the block, u dont tend to 'upgrade the block'... i think all u can do to the block is korek bigger holes for bigger pistons, maybe cut the block for added clearances if u stroke the engine.. and maybe add a block guard if its an open deck
  • Like
Reactions: leinnz
Is your car originally an auto or manual? The auto rad is much bigger. If it's already auto then just get a campro/CFE rad. It's thicker and bigger and almost PNP
Don't bother la. You might as well turbo. But you'll need to do a shit load more things. Any forced induction means you're gonna need pistons, head gasket, fueling, engine management... I hope you got a good budget.
minibeany
598
102
543
mine original is 1.5 manual. Does that mean need to mod to fit the larger radiator?
sanekit
Dec 9, 2015
1,616
157
663
yours is the short radiator ah? those long/wide radiator are for auto wira. mine was auto and using the long/wide radiator. then change to double layer. no problem, the radiator will fit properly. just need to get 2 fans with shroud only.
KHNG940413
668
56
528
johor bahru
He juz poison me but I amute to it.Hahahahaha
Now I juz wanna switch a new muffler (deep tone n not loud type)& extractor(stainless steel one mayb? Or even full set?See how budget go)
and I am juz sort of finish? Or isn't?Hahahahahaha
Brake upgrade also inside my consideration (upgrade steel hose &slote rotor)but juz slowly bit by bit mod as limited budget.
parakey
1,367
226
663
You did not mention any plans for forced induction. So why need to fit larger radiator? Was the previous one not cooling the engine enough? Btw, regarding your damaged radiator, where's the damage? Fins or just the top cover. That may be repairable
Hi, i know there has been alot of posts like this. However in all these threads theres like 20+ pages and theres alot of opinions and such.
So what i asking now is, can someone please list down some engines i can use on my satria neo (M-Line) 1.6 Auto. I prefer to stick with auto gearbox. So can anybody give me some engine transplant options?
Your help is much appreciated guys :adore:
