reset ecu
ler
175
KL/SEL
Hello all
I have some question about this matter...it's only to plug out your batery cabel it call reset ecu??need some advise...
powercable
88
read about this somewhere before..
to reset ECU, unplug the battery cable, then press the brake pedal for 20 secs or so to make sure all the electricty current residue is discharged from the ECU.
boyzone
2,669
38
5,148
unplug ur battery with 8 hrs time, after that, let ur car idling for 15min, u can get back the oem setting.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
take out only negative side of battery terminal....
leave it for at least 40minutes or one hour like tat....press ur brake for 3-5times n conect back ur batery
once u start ur engine...u can see all ur radio,clock setting all run oledi...mean ECU reset oledi....
RPM_freak
332
kLANG
??? which one is the right way la .. everyone giving one diffrent way .. confusing ..
EVO3gsr
301
if u r confusing
u take out negative side batery terminal n leave it overnite until the next morning...
pres brake 3-5times (for assurance), then plug back the batery terminal
if ecu din reset...i cut off ar.....but make sure u done it in proper way
mirage2929
93
I just wander why do we need to reset ECU? After we change air filter to a KNN type,
do we need to reset ECU? Comment pls
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
after chaNGEd to open port filter...ur airflow reading will be different from stock..
if u r lazy...u can juz leave it..let's ur ecu re-learn itself....
if u wan to do it fast, then u reset it lo...within one hour..ur ECU reset....all data lost....ecu start in fresh mind
RPM_freak
332
kLANG
Would it harm the ECU is reseting is done to many times .. ? ..
BlackSamurai
9,000 RPM
9,656
24
near 7-11
www.hcc.ne1.net
hawick said:
apologize for stupid question, what is the benefit to reset ecu? anybody can answer this for me?
i dunno about others car, but mine, after ECU reset. You can take the car for a ride, drive in the way you (fuel economic or powerful drive), the ECU will learn the new driving pattern, adjust the EFI to suite the driving style.
hawick
346
D'sara / S'ban
huakenny said:
ecu wil be in fresh mind....
oh i see, then i should have a try on my car.
fresh mind, re-learn? it's good news for me, because my wira (A) FC is quite high.
U know, Auto gear = underpower = heavy right foot = high FC, hahaha
my FC is 13.xx litre/km, terrible!!!
Thanks.
Yo guys!
need all ur help!!
On Friday morning at 3.10am, my fren was robbed of her car a WHITE MYVI SE PHE 9389 near the traffic lights frm NPE(at Shell Station) near Sunway Court heading to Sunway Pyramid. A silver Kancil knocked lightly into her car from the back and she came out to check on her car whilst 4 indian men came out, beat her when she resisted and drove off in her car leaving the silver Kancil behind. The PHE 9389 den made a u-turn back towards NPE from the...
