Remove Kenari oil filter
bryan90s
896
Hi folks,
In order to remove the old oil filter, normally mech will need to take off the number plate and 'cap-like' tool to loosen it.
My question is, can i use my good old wrench to do the job? Ne those normal wrench u can find at jusco DIY section.
g88
3,081
54
5,148
u need the oil filter wrench to remove it...
leongts
9
If you have left your car to cool down overnight, you can try to use your hand (yes, your hand) to try to loosen the oil filter first. If you can't, then only go back to the mechanic to change oil and INSTRUCT him to tighten the new oil filter with hand. On subsequent change, you can open the filter by hand already, provided you do it when engine is cool la.....
Our hands can actually provide the torque needed to tighten the oil filter. This was conveyed to me by both my mechanics at different place. No need any wrench coz wrench when used by inexperienced person, will do more harm than good (overtighten).
Regards.
bryan90s
896
i mean this type of wrench. where can i buy it
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
get it at spare part shop...it wont cost u much..below rm20...i oso got one..
it wil make thign easier if u use this adaptor to loosen /tighten ur filter....
if u dun hv the adaptor, u can use the normal filter removal (belt type)...no problem, just abit hard only as extractor is there....
bryan90s
896
i bought a so called 'Universal' wrench at ACE hardware. somehow i cant make it tight around the filter/ seems like kenari filter is too small....
how le?
Elitehunter
102
kenari oil filter is smaller than normal oil filter.
try get a smaller oil filter wrench.
or if u wanna loosen it by hand, use a cloth and turn it anti-clockwise like i did.
and to be easier, loosen it from under the car. no need to remove the plate no n cap like tool etc..
bryan90s
896
Just by hand power is possible? then to tighten it? hand also?
Elitehunter
102
yes it is possible. but use cloth to tighten/loosen la, more grip.
if use oil filter wrench also can but scared later overtorque, no good. it also damages the oil filter (scratch marks)
g88
3,081
54
5,148
for best result, would suggest use the filter wrench as oil filter have oil pressure running on it..hand might not able to tighten it that well
Hi to all sifus.Need sum help here.I'm driving a prelude h22a vtec.Took out the cat and added a hotbits resonator and one top cat bullet.My muffler is sebring.At 2.5 to 3.5k rpm there is exhaust drone which is loud and vibrating but after 3.5k the drone dissapears and the exhaust note becomes softer and sounds good.How to get rid of the exhaust drone?My mech ask to remove the bullet and add another resonator.What do u all think?Thanking u all in advance :)
