Questions on making 400WHP MR-2
Shady
35
1,508
Hey guys!!!
I have'nt touched my engine yet its bone stock........so before i start on my quest for power i wanted to set power goal!!! and i chose 400whp. I wanna know if its possible to attain that kind of power without modifying the internals of the engine.
If no, then what is the maximum amount of power i can put at the wheels without touching the internals of the engine!!!
Thanx!!!!
Regards,
Shady
tom's
2,865
76
subang
www.zerotohundred.com
Re: 400WHP on MR-2 without Internal modifications?
stock turbo can't produce that kind of power too....400whp on mr2 very scary....need to improve alot on handling 1st.....u need bigger turbo, internal hav to do, management, boost controller, good clutch,fuel pump n etc......i'm aiming for 350whp on my 3SGTE...next year project
khoo198
1,948
2,067
N9
which project car bro? celica o mr2? 350whp tht means engine need produce 4xxhp right?
iexit
1,874
59
1,648
Selangor
iexit.multiply.com
Speak to MRMIC2 - car already in that region of power, but i must agree that 400WHP on a MR2 is mighty scarry, and its going to be a bitch to drive on the roads. Unlike other heavy chassis (Skyline, Celica etc) 400bhp is very wild on a MR2.
yn_hell
310
24
400whp on a 1200kg car is really scary... it will be wild to the max...
1JZtezza
371
42
Standard 1ZZ has only 140hp with 170N-m of torque @ 4200rpm.
If you can build torque to 380N-m @ 7500rpm;you are there!!!....400WHP.
Figure this one out...WITHOUT changing engine internals.
Shady
35
1,508
from the looks of what u guys are saying.........i'm gona have to mod the internals to reach that figure, which i don't wanna do. So how much WHP do u guys suggest i can go for without modding the internals and guys i'm talkin reliable WHP. somethin that won't kill my engine!!!
yn_hell
310
24
3S-GTE Power Primer
have a look at this. :)
Shady
35
1,508
Very Informative material!!!! Thanx alot Man!!!! I'm gonna go through it and then get back to y'all with some questions!!!
MK84
1,804
11
www.mk84.com
400 hp on stock internal is possible at the flywheel. 400 whp on the other hand, hmmm...
Last time ran 340whp with stock internals with no problems, with nitrous and turbo upgrade.
Yong_5290
3,637
49
Klang
hotmail.com
i think running 340whp with stock internal with no prob is sooner o later got prob....the stock connecting rod and many other parts just cant cope wit tat much power
khoo198
1,948
2,067
N9
Green06
141
14
Pahang
B4 U go 400whp, beefup the car's handling capabilities..........that has alot of work U need to do such as the suspension, shockers, brakes, pay special attention to your car's arm geometries, set yr camber right etc, etc. Also U need to hv the right LSD, as stock LSD might not handle that power properly, tires is extremely important, these is to ensure yr car go straight rather than fishtailing. Do U really need 400whp?
Shady
35
1,508
I guess not........but 400BHP sounds good enough!!!! well!!! let me be honest with you!!!! Other than the reason that im in love with my car, my other reason to startin this project is I wanna build a Honda Killer!!! No offence to any1 here on this Forum but.....where i come from, more than
half of the street racing comunity drives a Honda and they think its a ferrari or sumthin.
Every guy u talk to says brags bout his crapy honda when it comes to the road all he can see is the rear end of my 2!! so thought id step the game up a bit since their brains started workin and their startin to use forced induction.
So I'm hopin u could post up a set up list for me, keep in mind this car is driven only on the weekends!
thnx buddy!!!
---------- Post added at 07:25 PM ---------- Previous post was at 07:19 PM ----------
U sound very promising...... may i know ur setup list and did u change the ECU???
and how much do u put out on HIGH BOOST?
MK84
1,804
11
www.mk84.com
Shady
35
1,508
Very neat simple setup. I like it alot!! I have a few questions though.
1) What Mods did you do to the head?
2) How does she perform, does she give you alot of toruble?
3) What do you suggest is a good turbo for street setup!
4) What are your views on MAP ECU and Power FC since i was gonna pick one of these ECU's for my setup.
Thanx 4 your time!!!
CHEERS!!!!!!!!!!!!!:wavey:
iexit
1,874
59
1,648
Selangor
iexit.multiply.com
MAP ECU? U mean switch your A/F to MAF i think. If your thinking of those BHP you will need a standalone already, PowerFC is the easy way to go but Haltech, Microtech all also can.
400bhp is not street set up anymore... :-D
Shady
35
1,508
well what do you sugggest then? I don't wanna go STROKER or anything like that. If you have any ideas please let me know!
And by the way NO.....i mean use a MAP ECU!!! check it out - : PERFORMANCE MOTOR RESEARCH LTD :
Let me know what u think.
Do u have any suggessions on a good Turbo. And do u think its better to get acustom exhaust or get a branded one. I was thinkin of (BLITZ NUR SPEC R)
Shady
35
1,508
Increase SPOOL SOUND
Does anyone have a method to increase the sound of the turbo spool....you know something like u hear on the Supras!! Damn those things sound like JETS!!!!!:stupid:
The MR2s i have heard usally have loud exhausts but u can't really hear the TURBO spool up!!
Leme know if y'all got sumthin!
THanx!
Shady
35
1,508
400whp turbo
Hey Y'all!!!
Does anyone have any good suggesion on a TURBO that's capable of putting out 400WHP for a MR2.
Hi frenz,
Need help and advise. There are few white paint spot on my leather seat. How can I remove the spot ? I was thinking to use thinner to remove it but afraid will left thinner spot on the seat. Any idea or better way to remove it ?
