More questions! sti inj+stock fuel rail on evo mani
Poacher
85
18
508
Auckland, NZ
Hi guys
Another question, sti injectors (565cc) + stock fuel rail onto an evo 6/7 intake manifold and runners?
Will this work? It means i can use evo mani (bigger than ours) and keep the same inj etc. Otherwise i will have to source evo injectors + fuel rail + resistor packs + plugs for wiring! :(
Thanks
Johno
stutzedward
3,416
561
I've never came across this mod before. I know many (like you) has used pink STis on original manifold + fuel rail but on Evo manifold, unheard. Will there be a big difference in terms of improvement by using Evo manifold?
Poacher
85
18
508
Auckland, NZ
Much better top end i would assume as it's bigger (longer) than ours, however our runners are longer giving better torque and response, shorter is usually better for top end.
stutzedward
3,416
561
Maybe you can be the first one to try out. If it works, then we can use as guide? Hehehe...
4gbanger
1,958
386
1,683
Johor/ShahAlam
johno is true. my old boss(one of the most famous tuner at johor) once thought me that longer runner is better for torque n low end. shorter runner is better for high end rpm.
Poacher
85
18
508
Auckland, NZ
I am pretty sure the much larger plenum will out weigh any difference and improve overall performance. I will have a look to install this weekend
russellc2
Sep 14, 2012
38
13
508
Wellington, NZ
I'm just in the middle of doing this exact mod! using an Evo 6 intake manifold with no EGR ports and no MAP sensor housing, so I'm externally mounting the OEM map sensor for now and have ordered a aftermarket mount for this.
I'm stuck though with the fuel rail... the factory Airtrek one doesn't line up too well with the Evo intake manifold so I'm going to try and get hold of an evo fuel rail to see if that fits better. It may just be the black spacer / insulators that are too thick but I'll try the Evo rail first.
The Airtrek manifold is quite large with long runners compared to the evo. I think with forced induction the differences between intake runner length are not quite the same as with an NA engine so with a shorter / smaller intake the spool should be a bit quicker / more responsive which would make up for any losses??
I'll let you know how I get on and what you will need for the swap :)
4gbanger
1,958
386
1,683
Johor/ShahAlam
longer or shorter runner still can give effects on turbocharged engine.. thats what i know..
u should bought the evo manifold together with fuel rail last time.. or better get the aftermarket set..
russellc2
Sep 14, 2012
38
13
508
Wellington, NZ
I've ordered an aftermarket rail to try so I'll let you know how the fitting goes.
Yeah Johno keen as to catchup - hopefully I'm back on the road in the next few days!
I'm removing quite a bit of the factory vacuum lines along with EGR valve etc (after disabling in the ECU) so hope it all still works and no check engine lights :)
stutzedward
3,416
561
As you're altering some of the vacuum lines, will there be impact to engine performance like high-rev issue, idling, full boost etc? I think those stuffs are there for a reason.
hye guys, im new here..hehe
just want to get some info bout the defrent between crossmember and subframe. because if want to transplant a myvi engine to kelisa engine bay will required to use storia or yrv subframe\crossmember rite?....den wats the defrent between kelisa and yrv\storia subframe\crossmember....very appreciated if could giv a details bout this....thanks...hehe
