Proton electrical problem.
capyjohn
Feb 1, 2024
5
23
So ive had this check engine light on my dash for some time and it gave me a p0703 code. This code has been there for god knows how long. I have tested the brake switch and changed it but still no change. Until one day is magically went away after i adjusted the brake pedal.... Buttttt it came back in after a week with the same goddam code. I jst tried removing the battery and drain the electricals, left it for 15mins and the code is still there. Ive also checked the new brake switch and its working fine. Everyone of my brake light and fog lights are working and ive even added a relay to the brake switch for my brake lock. As i though that the brake lock is drawing too much current. I even removed the brake start that was added with the physical brake lock.
capyjohn
5
23
Does this unit have fault code delete function. Don't think removing battery will erase the code....
Yes it comes with a clear code function. I have tried it and it works and even had a mechanic use their one.
In that case since you can delete the code and it still appears, means the fault is still there. You need to repair the fault first.
Like my SUV the O2 sensor code appears once in a while, after clearing it, will appear again after one month sometimes longer. Had is changed once, but came back after a year or so, therefore I keep deleting the code for the time being....... :smokin:
Is there anyone in this forum know where can i get the sporty look bodykit for an Optra 1.8LT car? its really hard to find the accessories for this car.
