Problems with vibration!
Jun 7, 2006
4
My FTO vibrates after I changed my springs to Eibach! Need help please!
Hi there.....I'm new here. I got a question, but, before that, please allow me to explain prior to the question.
I just changed my original springs on my FTO to the Eibach springs (two Saturdays ago to be exact). From then on, my car vibrates whenever the speedometer reached between 30km/h to 50km/h.
Therefore, I sent my FTO back to where I installed the Eibachs. The workshop claim that the problem lies in my drive shaft. So, I took it to another mechanic to have it checked. He replaced the drive shaft but there was no problem, so I put my original drive shaft back on. So I took is back to the tyre shop and replace the Eibachs with my originals, and the problem was gone.
My question is: What could be the cause of this problem?
Fluffy
3,870
>>klang<<
when u accelerate..the sound goes faster and faster..it would be ur driveshaft.
but if the vibration is at a constant "tone" then it could not be the driveshaft..
but anyway..it could be ur bearings..check them out.
jombiee
950
13
Ghombau
You changed the springs only right, replacing the standards spring fixing to your standard abs ? if the eibach shorter(sports type) ?
if this the case than you need a short stroke abs to match your springs.
Hey guys , I'm planning to do some tuning for my car. For the time being , I did the 4-2-1 exhaust only. and I got few questions to ask. For what I know is that I want more initial speed from my car.. Is it so called low-mid speed ? Which means I wan more pick up instead of high speed.. Cause I not gonna do more then 130 normally. Let's say from nought to 100 faster.. cause I really seldom drive beyond 130.
What shud I mod ?
I planned to have my air filer changed , is HKS a good product...
