potong spring!!
jeremy
309
kuching-penang
just wonderin those who potong spring, how much spring u cut .. measuring from either end,izit i complete circle? or semi circle.. n how low does it get if u cut 1 complete circle or semi circle? wat is the lifespand of yur ori absorber if u cut 1 full circle or semi circle...
thank u sifus sifus out there...hehe
DimDimer
385
dun cut. absorber lifespan will be very very short, but your 'sporty feeling' will wear out sonner than the absorber.
go out and invest on good springs.
acbc
4,615
8
KD
Don't cut!
However, if u know the right formula, u may do so... again, it is subjective.
jeremy
309
kuching-penang
i understand tat cut spring is a definite no no.. but u see.. since i throw in 2 12 inch subs + box into my trunk, the car slightly tilt to the bac ~~ planin to cut the front spring a lil , just enuf to make the car look balance..was wonderin how much is , just enuf..planin to lower it bout 1 inch in the front..
care for suggestions any1 who has done it b4?? hehe.. thanks
fstr
7,000 RPM
7,935
954
3,213
Sahara Desert
u potong u hailat.. dont do that!! if urs is proton, just buy those lowering springs in brothers for 88buck only...keep yer standard springs.
blue_hippo
978
cut springs is ah bengs styles...like what fstrader said..go get sport springs
boyzone
2,669
38
5,148
there is no advice to cut down ur spring.. especially at the front , u will totally lost control on ur handling when high conering... can kill u man ..
there is 2 way to solve ur problem.
1. change to sport spring.
2. just shim up 1 inch at ur rear absorbar spring base plate. ( better than u cut ur front spring. )
sam1741
1,188
i feel that after u cut the front
the front spring will be more stiff...
then when u carry passenger..
the back of the car will lower more.. ;D
BLaCkHoWLiNG
'(^^)|Most Awesome Member
8,648
1,349
PJ
www.autojunctions.com
u r not looking at the big picture... if u cut springs.. yes, wat u get is a balanced height... but wat u'll also be getting is:
1> Boat ride when u're over slight 'wave' imperfection on hignways.
2> Shorter absorber life span
3> imbalanced handling
u'll hate yr ride
jeremy
309
kuching-penang
erm.. well, guess it's a 100% no no to cut spring,,,my ride is a nissan sunny,,another quest, my front absorber is gas type and it's kinda hard... will it have a longer lifespan if i use lowered spring compared to a oil type absorber??
then the only option to consider is either to change to lowered spring or to shim up 1 inch at ur rear absorbar spring base plate, as recommended by boyzone...thanks all for your advise...appreciate it a lot
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Throw out your 2.5 inch subs + box....Hahaha can get lighter weight somemore.
gavan
1,408
Shah Alam
erm, cant say i hate my ride now cause im using cut springs at the front and sports springs at the rear, i wanted the rear to be harder than the front... :D
so erm, actually, its your choice anywayz, im now just having problems cause my car is too low and yeah, it gets harder but i would suggest you remove your springs first to see how long it is and wether would be come out from the base if your absorbers are fully extended. like mine, even if my absorbers are fully extended, the springs stays in place, even after i cut the springs.
so im guessing thats safe enough and the spring has to be of even length on both sides, one side shorter than the other then you are gonna have problems, so get it done properly if you intend to cut it.
btw, im driving a charade aura.
p/s : if you are just going to make the thing looks even, just remember that when you remove your woofers, then your rear is going to be higher compared to the front. personally, i think this setup for me is not good and hard enough, saving for coilovers now cause i wanna go for fast turns now :P ahhahahhaa.....
g88
3,081
54
5,148
never cut your stock spring...i have see car that cut stock spring, after car went over bump, senget one side since the spring loose out from the coil...
There’s no doubt about it, The Jungle Book is one of those stories that is just simply timeless. It has everything you could possibly want: lovable characters, singable songs, and a dancing primate. But who knew that a bunch of jungle animals and a man-cub named Mowgli would teach us so many life lessons? Not us. But lessons we did learn. Ones like these:
A 3 door...
