Ported VS. Sealed enclosure
ICE -In Car Entertainment
Charles
I brake very late....
342
47
5,028
Kota Kinabalu
Bert,
How bad you want that car next to you shake? :P
appleyard
773
Kota Kinabalu
i always like subs that play low and loud. Its like your car is falling apart.
km_chew
456
26
3,028
Penang
If i want to go low <<----(does that means the vibrating bass), which box should i use and what size? sealed or ported?
Yong_5290
3,637
49
Klang
hotmail.com
u wan it 2 go low n loud...ported...ported will supply u wit additional 3db a least compare 2 sealed...
appleyard
773
Kota Kinabalu
how low is low? it depends totaly on your preference. Usually ppl go for 28hz most will go to 30-35hz region.
like i said it depens on the subs itself. If you have a sub that is for SPL its possible to play low but at a ridiculous size (i'm talking 6 cu. ft or more) and the port will be like something like 14 inch long.
most SQ subs can play low at a smaller enclosure. Try and read the comparison for a ported and sealed and see which one do you prefer.
Yong_5290
3,637
49
Klang
hotmail.com
oh ya...appleyard...since u say ported enclosure is so good...y sound stream company recon their sub 2 be in a sealed enclosure?
just asking..no offence...hope 2 learn more
km_chew
456
26
3,028
Penang
Assume if you got a good monoblock (high power), and a good sq subbies (such as Eclipse <<--- example),
what is the size of the enclosure? what type should use to get those low vibrating bass? newbie here wanna learn more.. :P
appleyard
773
Kota Kinabalu
Yong
subs are designed to play the best in one specific enclosure only while will sound good or average (even worse) in other enclosure. Even Kicker recommend for SQ in a sealed enclosure and i did follow the instruction and the size of the box, its a 1 cu. ft sealed for CVR 12". it does produce some nice SQ but not enough for me. Btw i didnt say its so good, it has its pro and con compared to sealed and i'm into the pro of it.
Km chew
like i said, how low is low. For me 30 hz is good but i opted for 33hz. For ported, the bigger the size, the sub will be more efficient. You can have a 400w subs place in a 4 cu. ft box ported which will only need like 200w to play loud. The question is how much boot space can you afford? i can recommend you a 6cu. ft. box tuned to 28hz, but will it fit you car?
Kippo
263
IMHO no need to paste long. Just paste the link.
yong,
why some Subs company recommend sealed box?
well not all subs can work well (i.e sounds nice) in ported box. You can do quick check if the sub is suited for sealed or vented enclosure by looking at the EBP (Efficiency Bandwith Product) numbers.
You can derive EBP = Fs/Qes (look at the sub T-S parameters).
EBP < 50 : The sub will perform best in a sealed enclosure
EBP between 50 and 90: Flexible in selection, though higher numbers like ported boxes
EBP > 90 : use this only in a ported enclosure
why port the box if the sub can play low in sealed box?
If you want exergerated low freq. (hence the term loud and low)
Ported box+sub has steep roll-off?
yep. But same with high Qtc. sealed box+sub (cue small box).
Maserati designers may just be shocked to death at the sight of this. Never have they thought that an Italian firm, Ellena srl Autotrasformazioni would turn the beautiful Maserati Ghibli into a hearse. Ellena srl Autotrasformazioni is a company that provides fancy last rides for people, with Mercedes-Benz lineup being the other two model in its fleet.
It is not clear why the Ghibli...
