Kenwood compact carsubwoofer-Imported from Japan
ICE -In Car Entertainment
ken_wong
525
Your search for your car subwoofer ends here.With kenwood compact subwoofer small to medium car owners from proton to perodua (and even bigger ones too-tested on WAJA) and others can actually fit a full featured ACTIVE subwoofer immediately without any hole drilling etc.
This subwoofer is a dream solution for Van and MPV and 4WD and lorry as no selaed bonnet to fix normal subwoofer so the self standing subwoofer is best solution.
Just use a line out or pull 2 wires from your existing rear speaker , connect the 12V line (cigarette lighter also Ok) and you are ON!
This subwoofer is self standing unit with 100W x 6 inches x 2 drivers going right down to the lowest frequncy of 25Hz (really low bass).It`s amazing how Kenwood designed this and only available to Japan market??.You now in position to own this Japan imported subwoofer units.
Retails in Japan for almost RM1000.00 now sale RM400neg
Guranteed good condition
It is used item
no scrape,like new,99% new
Other details
POWER OUTPUT 100WATT R.M.S MAX 150W
Class D power amplifier provides clean and dynamic driving power .Frequency response 25Hz to 120Hz At these levels you can hear low bass notes not possible with other systems
6" x 2 twin loudspeaker system
Uses Kenwood 6" high power subwoofer matched with 6" WOOX passive driver for unsurpassed low frequency syntheses.It is equivalent of a 12inch subwoofer in your car compartment .
Highly rigid Aluminium rer cabinet shell construction
This gives solid streghth to small POD construction and cools the AMP down quick!
Extremely Compact Space-saving subwoofer
Size is only ~1?? feet by 0.5?feet!!
""When the cabinet is miniaturized substantially by the fact that the passive radiator is adopted simultaneously, powerful playing back of the bass is made possible heavily. Furthermore because the vertical ranging bracket which actualizes space-saving it has belonged, it is optimum to also
the compact car.(this is translated from Japanese web)""
Other features
Wired * remote control loading (6m)
Gain controls*
Cutoff frequency controls * 50Hz - the 120Hz
Phase adjustment -normal or inverted bass
Controls at your fingertip!
5.1ch theater system construction:
A 5.1channel of high power can be constructed simply combining with front rear speaker in your car
Comes with full accecories as below
integrated input,power and inginition ON cables,
user manual(japanese)
aluminium mounting brackets-2pcs L and 2 pcs I for anywhere fixing
spare fuses pack
spare extension power cable for long wiring
screw pack
foam pads pack for paddings
all in ORIGINAL kenwood carton
interested pls call or sms
019-8869822
AnQ
74
Kajang
pm me last best price u can give before my friend go to kuching
Autodetailer, the premium car detailing mogul has collaborated with us at Zerotohundred.com especially for the coming Time To Attack Finals to award anyone with a passion for photography for capturing the best photograph at the event this Sunday.
Darren:This is a photo community effort to cultivate more photographers in the area of automotive photography & motorsports. I believe with some...
