phoenix gold high end rca cable 5m
ICE -In Car Entertainment
This simple circuit makes it posible to monitor the charging process to a higher level.
Final adjustsments are simple and the only thing needed is a digital voltmeter for the necessary accuracy.
Connect an input voltage of 12.65 volt between the positive and negative poles and adjust the 10K trimmer potentiometer until Led 10 lights up. Lower the voltage and in sequence all other Led's will light up. Check that Led 1...
