Phoenix Gold AX-406A
ICE -In Car Entertainment
nguyen
May 11, 2015
41
506
The specs are as below:
-Delayed remote turn on output terminal: This delayed helps eliminate on/off thump caused by brand incompatibility.
-Front/Rear stereo inputs jacks: Accepts up to 9 volts Dc connect to pre-amp outputs of source unit.
-Peaks overload LED’s: LED’s are used to accurately adjust input sensitivity.
-Pulse width modulated (PWM) power supply: Reduces Ac ripple and impurities that would interference with circuitry.
-Front/Rear input gain controls: Allows variable adjustment of the left and right input gains from 0-20db. These controls are mono.
-Phase inverter switch: This switch shifts subwoofer output signal 180 degree “out of phase” relative to the high pass output.
-Subwoofer stereo/mono switch: This switch changes the subwoofer output from stereo to mono mode operation.
-Crossover 2/3 way switch: Control operations mode - 2 way mode- Front/Rear outputs are high pass only-3 way mode-Front outputs become bandpass (midrange) and rear output become tweeter.
-Parallel Fader switch: Used for fadable operation parallel mode- Ax 406A will accept front inputs only while driving all outputs- Fader mode allows unit to fade between Front/Rear outputs.
-Fully muted output circuitry: Attenuates the AX-406A inputs and outputs 25dB during turn on/off.
nguyen
41
506
---------- Post added at 01:51 PM ---------- 6 hour anti-bump limit - Previous post was at 01:44 PM ----------
---------- Post added at 01:52 PM ---------- 6 hour anti-bump limit - Previous post was at 01:51 PM ----------
Does anyone know or have insider info on whether Honda Malaysia is bringing in the new Civic Type R? No doubt it's the euro version Civic but HM might consider making an exception for high performance models?
