Peugeot 405 gri engine problem
aces_high
8
Nakon-rachasima
Yesterday, my engine lost 2 cylinders,I measured the compression test for each cylinder.
The guage showns
cylinder 1 (clost to the gearbox) : 175 psi
cylinder 2 : 100 psi
cylinder 3 : 0 psi
cylinder 4 :165 psi
And I saw oil smoke went up in the oil measure stick pipe
What happened ?
Gasket or piston oil seal ring or anything else ?
Thank you very much
dellorto
Jun 17, 2013
46
Hi aces_high , I guess the gasket , piston rings & liners r badly damaged . Rare 2 come by but possible . Need 2 perform a top overhaul as remedy . BTW , is urs the XU9J2 version ???
ken yeang
6,000 RPM
6,617
1,327
The absence of compression is not just failure of gasket or piston rings. I suspect it is more than that. I hope TS could find out the root of the prob.
I know a case last time that the compression test showed very low compression.....and it was due to a serious case of piston rings "makan".
Piston rings makan will still have some compression, if 0 can mean piston gone.....:smokin:
to all USJ members,
pls look out for 2 suspecions malay in their 20's driving a silver color toyota camry (new model). as this 2 fellow was commited to several house robbery case in USJ area such as USJ 11, 9, 5, 2 for the past few months.
"my house has become their target on 15th of June, about 5.30pm, they have run away with our cash money, watches, jewelery, lap tops, handphones, digicam. while in the meantime i have been forced to goin to the bank to withdraw my saving to them after...
