Pfft i'm sure a K&N drop in for your myvi would threathen your monthly budjeting.I'm a poor DIY-er. If I were richer I'd do this as a potential Izso Mythbuster. Hehe
Hi guys, yesterday I changed my heavily restricted OEM air filter on my Perodua Viva to an aftermarket drop in stainless steel air filter. Cap ayam brand for RM68. Well I was thinking,since its only an extra of rm20-30 from a brand new original air filter,might as well I give it a try.
The acceleration of the car from stationary position has definitely improved. But that 'feel' somehow decreases over time as it reaches 80km/h. I had a hard time accelerating after 90km/h, a really hard time. Only managed to accelerate up to120km/h and the meter just stops there at 120km/h despite flooring my pedal. Used to be able to run up to 140km/h without any hassle with stock air filter.
Clearly,the solution here is to change the aftermarket air filter to a more reputable one. But can someone explain to me what is the problem with this specific aftermarket air filter?
Thank you in advance.
So actually it's not really recommended for stock car to put in this kind of performance part uhh.if u done intake mod like port n polish, changed intake manifold, etc.. 'maybe' drop-in can give better result.
for std setup oem filter does the job well..
cold temperature can give more power/respond. ecu will detect temperature from intake sensor.
usually stock intake snorkel will get fresh air away from engine heat.
It's not a performance part at all, an aftermarket drop-in filter does is allow fractionally more air in than the standard element. Anyways the only way to make use of that extra air is... to get your car tuned accordingly. You still keep the standard airbox, hoses, whatever noise cancelling chambers/pockets they have from factory.So actually it's not really recommended for stock car to put in this kind of performance part uhh.
ohh is it, what if re-align the air intake hose away from engine? Put it in grill area?
Who says that normal paper filter is restrictive?
Driving in Malaysia with all the dust and black diesel smoke coming out from lorries, Id rather stick to paper filter than risk my engine.
Tried all sort of 'performance' drop ins and open pod. All will leave a faint film of dust inside the air box.
So imagine how much dust is ingested into your engine?
Driving in Malaysia can be considered one of the extreme conditions for a car.
for turbo, ill go for open pod.agrees with you on that, but finding oem replacement paper filter for my daihatsu mira L502 is kinda hard, once i found rm80 for one piece even then have to order. even drop in are practically non existance here in malaysia....
btw, for a turbo'ed engine owner... most will change to aftermarket open pod if changing to a bigger turbo
I'm curious, what engine have you tried these 'performance' drop ins & open pods on? :hmmmm:Who says that normal paper filter is restrictive?
Considering the heat inside the combustion chamber is ridiculously high, whatever dust and dirt that gets sucked in is gonna burrrrrn babeahhh..Who says that normal paper filter is restrictive?
Interesting you said this. I did test this once before, I drove around without a filter in KL for about a month. Filter-less. Completely. What I did was take the ori filter, cut out the paper element and just left the frame and installed it back.not all dust n dirt get burn... some will stuck inside intake system.. tb, manifold.. sensors inside intake system (if got) also will be coated by dirt..
ur rocker cover inside will contaminated by dust/dirt also if ur engine breather system still stock connected to air box.Interesting you said this. I did test this once before, I drove around without a filter in KL for about a month. Filter-less. Completely. What I did was take the ori filter, cut out the paper element and just left the frame and installed it back.
After a month of driving like that, I dismantled everything. The only thing that I found was that the engine oil got dirty verrrry fast. TB was actually very clean (well, to be fair it was the usual 'clean', nothing special, nothing too dirty, nothing too clean), intake was the usual clean and my low end torque was crap (was still auto back then). High end was fantastic and the intake roar was unbelievable. But then again the TB and everything was ported and polished so that might have something to do with the lack of dirt sticking.
Btw, when I said the oil got dirty very fast, it's like this : Today I change oil, check the dipstick it's bright yellow. Tomorrow I check it's still yellow. One week later it's almost black. 1.5 weeks later the oil was so black I couldn't see any yellow. Changed the oil after 2 weeks of using a semi-syn oil. Bloody hell.
He is right on. Stock air box is good to keep air cooler, with K&N filter should be good enough.If I'm not mistaken, the Viva ECU isn't adaptive and runs based on a fixed fuel map right? If yes introducing more air would just make it run really lean. I don't think you should use the stainless steel mesh filter as those are very free flowing. At the very least consider getting a performance non-stainless steel drop-in like those from K&N/Simota/Works/Pipercross.
But you gotta love that induction noise!
