Part 2: Any Lancer A172 Or A174 Die Hard Here?
e-fan
15
nilai
i'm using g54 starion gearbox bro..:idea:
but must custom made the bell housing:biggrin:
---------- Post added at 05:18 PM ---------- 6 hour anti-bump limit - Previous post was at 05:16 PM ----------
salam sume??da sunyi plak post ni???:hmmmm:
mane otai2 ni?
sonyap yo....:hmmmm::idea:
VtinoAJV
Jan 27, 2014
5
Kuching
Hi fellow die hard EX friends!
Anyone has any idea what suspension type lancer a172 is using? 3 link or 4 link?
Planning to install anti roll bar due to rear end like to sway side to side, not only roll.
I have not seen UR made any Anti Roll bar for a172, has anyone know any replacement or DIY design? thanks
dirtymind
131
ermmm... we not the same type of that 4WD Lancer EVO onwards mate...
try to replace all the bushing and see either its improved the drifting issue... or get the teflon bush as performance part...
VtinoAJV
Jan 27, 2014
5
Kuching
Ahh okay, i wonder is there anyway to find polyurethane bush for it? since bush is kinda wear and tear thing.. PU bush will last much longer right?
Just found out the car running on 4 link, something like old Mustang or pro drag racers use. Lancer EX also does not have panhard to control the lateral movement of the rear end.
Will figure out a way to do this, at most diy a custom mount on to the trunk and weld on a bracket on the rear end hahhaha
Another first for Malaysian grassroots Motorsports, SSO this time will be held at the Bukit Jalil National Stadium. But, what else would you expect of the crew that bought you SSO Danga Bay and SSO One Utama? After 3 rounds the Championship is still up for grabs...
