Is it Lancer CK2A 6A11 parts is hard to get?
June Mai
Nov 7, 2012
5
503
www.facebook.com
Is it true?
My lancer dead for about 2 weeks now n the mechanic said that my distributor burst. he claimed that parts for this V6 is hard to get. I am so worried, especially he ask me to pay him as the car can be start last week, when i paid till now not working.
Someone out there pls advice me, reminded him this morning if by this evening my car cannot be ready i demand my money back and also all my parts that he took.
another question:
i tried to seek advice from 2-3 mechanic and understand that 6A11 V6 engine is using sensor not distributor... again pls advice me.
Thank you all.... ^_^
MOD: if thread repeated, please remove mine.
Solty8
256
31
3,028
Bro why your CK2A use 6A11 engine ? 1.8 V6 SOHC ? U convert this engine or how ? Your car actually b4 send in to mechanic what the sympthom ? Still can drive just no power ?
June Mai
5
503
www.facebook.com
Thanks Solty8. Yes, converted to 1.8 V6SOHC. The car dead when driving n mechanic came n checked. stated that the distributor burst, parts hard to get.
Now the car is ok after i demand my money back, the mechanic done it for less thn 3 hours. i went to other wshop to reset all sensor due to the engine check light is on. so far so good, smooth driving.
---------- Post added at 02:52 PM ---------- 6 hour anti-bump limit - Previous post was at 02:49 PM ----------
Oya... sorry i suppose type Lancer CK2A with 6A11 V6 engine....ngeee. ^_^
budakkampungaje
317
38
Dengkil
a little info bout 6a11
Displacement, cc: 1829cc
Engine model: 6A11
Max.power (Net),
kw(PS)/rpm: 135 ps (99.29 kw) / 6000 rpm
Max.torque(Net),
N*m(kg*m)/rpm: 17.0 kg*m (166.71 N*m) / 4500 rpm
Power density: 8.37
Engine type : V type 6 cylinder SOHC24 valve
Engine information
Fuel system: ECI-MULTI (electrically controlled gasoline injection)
Turbocharger: No
Fuel type: Unleaded regular gasoline
LEV system (Low emission vehicle): No
Compression ratio: 9.5
Bore, mm: 75
Stroke, mm: 69
Final gear ratio
Fuel consumption at 10-15 modes, l/100km: 8.1
I have been changing setup here and there due to some mod on engine.
Currently 1.5CC engine with 0.6 bar and abt 140 BHP.
I had tried remove Cat, then my low end speed is really like snail. Even stock 1.0CC car also can faster then me.
I put back the Cat and is fine, but from 120Km/h to 180 now is just abit faster then NA car.
Before put back the cat, is very very very fast climb up to 180 km/h
Now what should i do?
Change to Hi -flow Cat?
Change muffler with stock Cat...
