Need some info regard accord...
seizai
937
I planning to buy used accord. Need do some research, hope somebody can help me.... :hmmmm:
1. year 95 & 96 model, any "normal" problem will happen? like here leak there broken...
2. which model sm4 / sv4 consider value to buy? etc, body structure, engine age, absorber problem, parts maintenance....
3. MT or AT car more "tahan"?
Any accord owner here can share share?
ken12292703
Drives a shopping cart...
1,542
8
5,138
SoMeWhErE
Luck plays a very important role here. It really depends on previous drivers.
Rust, leaks, failed components and etc problems can be hidden for a short period while looking for a new owner.
Leaks can be washed and glued, rust can be top patched, failed components replaced with failing junks and etc.
Prepare to fork out cash to maintain an old car. See which model you prefer and go for it. The older it gets, the more $$ you have to use.
Manual transmission would be preferred, good oil changes will keep it fresh.
Good luck bro. :biggrin:
mag9556
2,770
43
1,648
Try to find those that have change the engine by used car.. will be better...
Normally used car will tender car back and recond it..
I have saw it a few times already... buy liao what engine u want... they will change it for you.. coz I have a fren that brought a perdana non V6 and the used car change v6tt for him...
try to check shop by shop.. u will get it...
good luck...
Do you guys know the standard price for engine bay repaint and wire tuck? I was quoted ~1.5k for civic EK.
