need some help to fit in fuel tank in st150
sof00
46
1,508
im using 4age engine which using fuel injection system.... just wanna if any tank with fuel pump that build inside of the tank..that can fit in to st150? anyone ? :banghead::banghead::banghead::banghead:
ragerunner
383
65
AE82/ST150 efi tanks will fit directly but are very rare.
Your best bet would be to get an AE92/101/111 efi tank and modify it into your car. Not an easy job but experienced mechanics should be able to get it done. AE92 tank should require the least modifications. Using AE101/111 tank would allow you to use full aftermarket exhaust sets designed AE101/111 later on as well as it has the gutter for passage of exhaust pipe. Your pick.
hi guy..
i would like to ask anyone use sachs super touring or greber on inspira before?
saw these 2 absorber currently
or still kyb excel G is a better choice?
inspira excel G got local made? or only Japan made is available?
