Need guidance: Toyota Corolla AE92 Blacktop 20v
Aug 10, 2022
21
Hello guys i need help here, I have a problem with my 20v blacktop it puffs out black/dark grey smoke when i downshift/braking and when i accelerate after braking.
Problem is it happens when i don’t turn my ac on it puffs a lot but when my ac is turn on it the smoke disappears and lessens.
I changed the spark plug to the NGK iridium ones and service with liqui moly 15 but the problem still remains. What could be the problem cause when it idles it doesn’t puff smoke or when driving, only when braking and accelrating after braking with the ac off it puffs out a lot of smoke.
Thanks sifuu.
brokenjars
229
16
Kedah
Seems like u got a few problems there..
Are your engine oil consumption high?
Are your fuel consumption high?
Any mods?
ryce
21
Any mods?
it doesn’t burns that much oil.
yes fuel consumption is high.
stock engine only change is ngk power cable and air filter.
brokenjars
229
16
Kedah
Blacktop ecu parameter range is quite big, so it might not trigger error code. Try change new oxygen sensor if its still using old one. It wont hurt and the old one might be needing replacement anyway
As most modern car nowdays have a returnless fuel delivery system,how do you guys install a external fuel regulator to compensate the need of more fueling?
