toyota camry ac light blinking
May 9, 2011
Hi guys,
I am studying in michigan, usa and my ride is a used toyota camry 2000. My ac light keeps blinking whenever I stop at junction and hot air will come out. I have to keep switching it on again. I have sent my car to the toyota service center and it cost me $2000 to fix the problem. Then, I did the internet research and most of the main causes were about to change the magnetic clutch relay, which I already did. But, it only last for a couple of weeks then the problem is happening again.
Please help me, have a good day.
When idling check the magnetic clutch whether it is running. If blinking means it is going on and off. If clutch running fine then it is something else.
ken yeang
6,000 RPM
6,617
1,327
toyota cars are prone to such issues....My mech says it was likely due to the circuitboard...
ken yeang
6,000 RPM
6,617
1,327
My mechanic fren has been trying to solve this prob. vEven his own toyota SEG has the similar prob...ahahhaha
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
check the gap of the clutch.
i dont know your specific gap but it should be pretty narrow.
too much gap and the magnet cant pull the clutch.this happen when driving very slowly or stationary.
when u rev past certain rpm,the clutch will engage again.
i am not sure abt toyota whole system but on a merc,even the old w124, the compressor wont engage if it detects low gas pressure.
Most air con system with pressure detector will cut which pressure is low, means not enough refrigerant to run the system....
The Formula One pre-season consists mostly of the drivers musical chair and launching of the teams new race cars for the upcoming season. It’s a mostly mundane affair right o the point that those cars roll off the stage and onto the circuit for some pre-season flogging to iron out the bugs and let the drivers have some seat time...
