- Dec 31, 2005
- 21
- 0
- 1,501
I bought the car almost 1 year only and still less than 17k km.coil buffers are supposed to help sagging springs la, not to soften them.
ericartman : How much do you travel? Perhaps your absorbers is worn out. Trust me on this - nothing is more comfortable than stock. Changing to any of those springs you highlighted will make your ride even more stiffer. Stock is the softest you can get. It's most likely your spring and/or absorber is worn out so check for oil leaks on your absorbers. Kayaba is the OEM manufacturer so buy back the same Kayabas. You can probably try to opt for Monroe Reflex absorbers paired with stock springs too.
YYC : 1.3 will fit in the 1.5 car meh? Wouldn't the front dive since the engine is bigger/heavier?
Dont think its worn out because its like that since first time and same with other myvi 1.5s
The reason on why going for adjustable is because there is an option for not only hi low, also soft hard.
If the softest option on adjustable is more comfortable than my current standard, I'll consider getting full adjustable.
