Myvi 1.3M Shaking/Vibrates at 70-80kmh.. HELP ME!!!
mebontot
Jun 25, 2011
20
503
MY
Dear all..
Did anyone ever had same problem as mine? ; My car start to shakes/vibrate during normal driving in between 70 n 80kmh. at 1st i tot it was the alignment or balancing.. so i did the balancing n alignment and still didnt change anything. :confused: i can say this problem start after i replace the stock crank pulley to the lightweight type. i havent check the engine mounting which i suspected the cause.. if i release the pedal within this speed, it stop shaking d.. but when i start accelerate again, it happen again.. but after 80kmh, no vibrations d. hmmmm.. its not that serious acctually,, but its very disturbing.. :banghead:
help help help.. .:wavey:
nyantong
192
50
Its most likely that the light crank pulley was improperly installed. Take it back to the shop or go to a more reliable shop to have it checked and reinstalled.
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Either that could be your mounting or check whether your rims are dented. My car, not myvi but it
was shaking badly when I drove, end up is cuz my rims was badly dented.
The other car will be engine roaring loudly and engine vibrates...so mounting checked, is broken...
mebontot
20
503
MY
i ever asked few workshop d. they say its not from the pulley.. i suspect the same thing oso last time.. they say mybe its causing from engine balancing.. adoh2..
red mini 8 7 8
162
In the car
Bro, i have read this somewhere and it is best not to use lightened crank pulley that doesnt have a harmonic damper. Which can cause crankshaft failure. You can do some reading in the link below.
Why dont you revert back to original pulleys?
ATI - The Dangers of Power Pulleys & Understanding the Harmonic Damper
If it's a dented tyre you'd feel the vibration all the time.
I've had a wobbling pulley before and it doesn't vibrate the entire car. But have it checked out anyway just in case. Look at the pulley with the engine idling, get someone to accelerate and look if it's vibrating.
And have on-wheel balancing done. You might have an uneven tyre or something else.
mebontot
20
503
MY
i just bought my rim. this problem occur even b4 i change my rims. at 1st i tot its from the tire or rim.. after i bought new one, still the same.. i suspected the mounting oso.. couse i can feel the vibration inside the car.. aiyaa.. still bz working.. no time bring to workshop.. anyway thanks.. :wavey:
---------- Post added at 06:37 PM ---------- 6 hour anti-bump limit - Previous post was at 06:34 PM ----------
before i install the light crank pulley (LCP), i have few doubts oso.. but i get consult from one person who is using it for almost 5 years d, he didnt have any issue on it.. plus, he himself got his car very2 super moded.. mybe it depends on the engine design n type also.. :confused:
---------- Post added at 06:40 PM ---------- 6 hour anti-bump limit - Previous post was at 06:37 PM ----------
i have checked the pulley visually. and i have done wheel balancing twice.. still the same.. what i worry now its mybe my gearbox or driveshaft.. adohhh2
And you don't get the vibration at any other speed? It's not rev dependent? Damn weird to experience it only at that speed. Wheel bearing spoilt? Or drive shaft?
ixeo
4,788
3,080
KL, Malaysia
shaking when accelerate, no shake when no acceleration? check your drive shafts.
mebontot
20
503
MY
yup yup yup.. only in between that speed.. hurmm..
---------- Post added at 11:00 PM ---------- 6 hour anti-bump limit - Previous post was at 10:59 PM ----------
yaaa.. if didnt accelarate, not shaky.. only during accelerate.. is there any way to check it physically?
Driveshaft cannot check. Most of the time it's a giveaway sound and if continue to ignore, it'll just drop off eventually.
mebontot
20
503
MY
YEAYYYYY!:rofl: My car good liao.. its my driveshaft! hahaha.. now no more shaky2.. so syok drive.. like brand new.. hahaha :driver:
alienklipsch
Mar 14, 2012
13
Hey bro...im facing the same problem as u...and i take to garage check they said mayb the driveshaft problem...i wana ask is how is ur problem solved?change it or repair?and may i noe how much its cost oso thx!!!
dillon24
Apr 1, 2013
21
503
hi ! since you have change to a new rims, i would recommend you to check your absorber, I have face the same problem before when i have just change my rims, check on the front absorber mounting. hope it helps. :biggrin:
Having this problem where if my car don't start for 2 days, i will need to jumpstart it... happen for 3 weekends in a row...
Changed the battery to AC Delco MF but still same problem... switch to another AC Delco batt but problem still persists....
However, when car starts, charging show 13.0 Volt .... sometimes when idle at traffic light.. drops to like 12.2 Volt .. and even once to 11.5 Volt ....
And when engine is off, its about 12.4V only ... is this a sign that my alternator is a...
