Mods on waja 4G18
joshua7paul
461
26
Hai guys.
im currently running one 4G18 with adjustable pulley (1.5 degrees up), Sard fuel regulator, 4-2-1 aluminum piping. with the current setup im getting a top of 220km/k. What i want to ask is this, any more mods can be done to improve it?..ive heard about changing a bigger fuel pump.any suggestions?
by the way, my rims are 15"..if i change to 16" will it effect the performance of the car?..im talking about japanese rims not imitations.do advise.
thank guys.
allance
337
8
install piggyback ecu like e-manage / afc neo or other n change to stage 2 high cam if u want! no need change ur fuel pump if u not do any big modification!
if stock saiz is 205-50-15 change to 205-45-16 is ok! not change large saiz like 215/225-45-16 u will b lose power a bit or performance
joshua7paul
461
26
thnx guys..
no tyre size is 195/55 only..planning to go 16 using 205/50..ok or not?..
btw..the ECU thing..how much does it cost anyway?
allance
337
8
i think u can use 205-45-16 is better look n light weight than 205-50-16!
cost ecu like e-manage RM1500-1700 with dyno tuning !
joshua7paul
461
26
thanks for the input guys..will check out the e-manage..
one quick Q...clutch plates..i noticed my car..during changing gear..in between gears...can hear sounds..like something lose kind of sound..any idea?...
