Myvi lagi best 1.3 manual mods
Emmtiga
Apr 17, 2015
12
Hello, I have car which is Myvi lagi best 1.3 manual that already finished it’s warranty so I thought I want to do some modification. So, i would wanna ask for the otai's advice before i go do something stupid. I've done some research on what to do but I want to know does those part really work or just placebo effect
Things I've done:
15" 6.5jj rims w goodyear f1
Sports spring 4flex
The list :
Spark Plug Iridium
Exhaust system
Tein adjustable suspension
Performance clutch
Lcp
For exhaust:
I've asked a few people, they recommend me using 4-2-1 extractor since I'm going for top speed with double stainless steel bullets and a s-flow kakimotor muffler. But i still need explaination on the piping. Either straight flow or not. And what are the good and bad about it.
If you guys think that some of the things that I'm gonna do is stupid let me know and please suggest other better mods. I'm not gonna mod my myvi for track (yet). So, not going for a heavy mod like change engine, korek block and all (yet). I'm still a noob in this thing so, if you have any better idea let me know and if possible can you explain in what way is it better. And please dont use too many acronyms because sometimes I don't really understand hahaha. And also can you also suggest me the brand for the recommended items too.
I'm an aggressive driver. Like speed and love to layan corner. Hahaha.
Thanks guys
ixeo
4,788
3,080
KL, Malaysia
Ftuned suspension.
Forget the exhaust system, get this.
And before anyone else says anything here's a fuck you if you recommend otherwise. Everything else is a waste of money on the K3VE. PnP head, balancing, high compression, etc. all is rubbish. The engine has a long stroke, vibrates a lot, its simply not suited for N/A tuning.
I can confidently say so cause I did N/A tuning on K3VE, and I now have a turbocharged one. So don't talk through your ass.
Want to play N/A get a Honda.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Hehehe....a snail is the easiest way to bump up the power.
Additional mod to compensate are;
-better brakes
-better handling:some strut bars
-better cooling if the stock one cannot cope
Emmtiga
12
[/COLOR]
-better brakes
can you recommend me the brands and types. :D
---------- Post added at 11:17 PM ---------- 6 hour anti-bump limit - Previous post was at 11:16 PM ----------
Ftuned suspension.
i'm sorry. im kinda new in this - noob. what is that btw?
Turbo charger.....:driver:
---------- Post added at 12:15 AM ---------- 6 hour anti-bump limit - Previous post was at 12:14 AM ----------
Ftuned suspension.
Add more horses using siput.....:adore:
ftuned = brand.
suspension = suspension.
Get ftuned suspension. That's what Ixeo said and I didn't know they made suspension for the Myvi.
Since you like speed and cornering, spend money on upgrading the shitty brakes la. Servo, brake calipers, brake pads, rear disc brakes, steel braided hoses.
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Agree, focus on improving the car handling 1st rather than go straight for power. Like the saying...
I think wrong leh!
If you can't go fast with 90hp, then with 900hp you can't stop.......hhahahhahahahhahhahaa:rofl::rofl:
jerrysiow
407
146
1,543
Seremban
Hi, no offend here. You're so wrong to mod a myvi to whack the goddamn corner and high speed cruising. It just a tiny car take you from point A to point B.
And as what Ixeo mentioned up there, do not waste your hard earn money on NA setup. It's totally not worth it. If you really wanna go for high torque, get the snail.
I do found out this is a very informative web you can refer to: Perodua Myvi Turbo
Emmtiga
12
First talk about budget you have.
i'm not planning to use high end brands and all. I was planning you guys to suggest a brand that's not very expensive yet good in quality. like suspension, tein is so mahal but good in qualty. on the other side, HWL's quality is quite good (from reviews) and not that expensive as tein.
---------- Post added at 08:42 PM ---------- 6 hour anti-bump limit - Previous post was at 08:40 PM ----------
ftuned = brand.
is that all for handling that i need to upgrade? how about ARB? Strut bars? are those important?
---------- Post added at 08:46 PM ---------- 6 hour anti-bump limit - Previous post was at 08:42 PM ----------
anyways, anyone here knows about the perfect myvi gear ratio?
How to have perfect gear ratio? Depends on one's usage, so is normal or close ratio or are you going to custom make?
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
Another thing to bear in mind is that, if you want adjustables suspension or real good handling, comfort will be compromise. Just a reminder if you are still gonna ferry ppl around then cannot be too stiff. Unless u drive alone all the time
But mine ferry more people becomes comfortable. Drive alone then bumpy like mad......hahhahahhahha
on the last dyno 2 days ago , we manage to hit 195WHP on our track car but the car lost compression and the car need to be tow back to workshop , after dismantle the head we found this
what kind of problem can cause this damage to the cylinder head?
