Modifications done to Inspira
Shinjite
864
120
1,543
Klang
K Wng - Kaki Motor: 4 - 2 - 1 Extractor cost me only RM380 + Flexible Hose - around RM400+. Power Zone is too too expensive! I have the same feeling about Open Pods, that is why I refrain from using it. Tuning is done my my buddy: So no cost!
Bro, for cams maybe you can try PZ cams....they have for Lancer
Cam spec and duration not sure, you will need to call them
icechong
43
with the free service voucher given by proton, there is no gear oil change. But it is not expensive. I did the flush plus petronas gear oil, only about RM50.
DM3
278
14
PJ
actually for free service given up to 50k km will cover the gear oil change also at 40k km
jamesweh
262
21
I am getting piss off wt Proton Service ctr in USJ which is right next to my house: The earliest appointment available is 23/02/12. I need to do a 40K service. If gear oil change will help, I will be using a better gear oil like Torco soon. I cant remember, how many free service we have but surely I will not use Proton next time when my free service ends. Thanks for the tip that a change in gear box oil will help in gear changes. But still, I am worried that its really the sychomesh in 4th gear that is screwed.
DM3
278
14
PJ
bro go to Eon for slightly better service and also they know more on mitsu/lgt items but then again for MT is the same anywhere.
yea better gear oil like torco etc will be much improvement but do complain to them on your gearing issues.
jamesweh
262
21
I also using Torcp 100% Synthetic Racing Oil 75 W - 140 GL6, it cost me RM110 per liter. I bought it at Eneos. If you want I still have 1/2 liter, I can give you for free. My other manual has a LSD and needs a different grade.
jamesweh
262
21
Its ok bro: Most important, it solve my gear box problems ( I was getting a crunch sound when ever I don shifted from 5th to 4th gear). The problem became worse when the gearbox was hot after running on B roads where you constantly have to downshift from 5th to 4th gear.
Most racing gear oils also using 75 - 140 like Motul.
I prefer a oil having a wider viscosity, standard is 75 - 90. As the hotter your gearbox gets the thinner the oil becomes. And the lower index is still 75 W, so your gearbox will still be smooth to change gears in the early morning.
My gear shift is now very smooth.
I would recommend Torco as it is still cheaper than Motul.
mydvdrom
105
bro, i think we might not be on the same wavelength here. hahaha. i am referring to engine oil and you are talking about gear oil. no wonder the viscosity you mentioned is so much different from standard engine oil which is 5-15W 30-40. hahaha. any idea on which engine oil viscosity from Torco to go for? even their SR-1 range has many viscosity to choose from. lolz
jamesweh
262
21
O....sorry. I am still having the FOC stuff Proton puts in. But Yes, I will be using a good synthetic oil like Torco. I think for Engine Oils, I wont pay more than RM70 per liter.
mydvdrom
105
i am using too the free stuff. but the problem is service interval is 10k and the oil is semi rated for 8k only. i m planning to bring my own fully syn oil there next time and take back the semi freebies.
theinspiratuners.forumer.com • Login
RM60-65 but no idea which viscosity to choose from. anyone got any idea or experience with Torco?
hello to all sifoos out there...
i am driving a wira with 4G93t gsr... ecu no. 5660....i have noticed that my car didnt have speed cut..
wat bugging me is that... everytime i pass 180km/h.. i didnt know how fast i go.. instead telling lies like " i think my car go 190-200 edi.... hehehhehe (and afraid being lanci)" so i guess i wanna be a good boy and have a RSM to tell my speed... ok here comes the dillemma...
instead buying RSM... shud i get AFC neo???.. because mebbe later i...
